Question about The Health & Beauty
Kymco Maxi XLS it just keeps beeping when I switch it on and is there an easy way to pull the lever to put it in and out of push mode I can't move it
4 Suggested Answers
  • 166 Answers
SOURCE: 1999, 93 convertible top starts to open or close sid beeps.
check your convertible top control module and top latch position sensor/switch
Posted on Aug 31, 2009
  • 7353 Answers
SOURCE: 2007 pt cruiser, very hard
The cable is broken. Call the dealer I'm sure they have them in stock. (maybe)
Posted on Sep 07, 2010
conrynsilver
  • 56 Answers
SOURCE: I have a 2006 wrangler
You have a broken shifter cable. The inner cable is broken though the casing may look fine.
Posted on Oct 24, 2010
I have a 2006 honda shadow aero. engine dies when put in gear. kickstand switch measuers good at plug...clutch switch measures good...clutch disengages properly...what else can it be?
Hi, Dan the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Dies when put it in gear 2003 Honda Spirit VT 750
Bike only starts in neutral and Dies when put in gear
Honda VT750C2 Shadow Spirit Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C 2005 Shadow Aero Owner Manual
Apr 29, 2017 | 2006 Honda Shadow Aero
Neutral safety switch problems 1992
Hi, Anonymous the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
1500 goldwing neutral light wont come on GL1500 Information Questions...
Neutral safety switch GL1500
Honda GL1500 Service Manual
Honda GOLDWING GL1500 Owner Manual
Apr 30, 2014 | 1992 Honda GL 1500 Interstate Gold Wing
My honda valkyrie stalls when shifting from neutral to first gear wile still holding down the clutch
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1500 Dies putting it in gear GL1500 Information Questions goldwingdocs com
Honda 1997 GL1500C Valkirie Owner Manual
Apr 06, 2014 | Honda F6 C Valkyrie Motorcycles
1800 vtx stalls after clutch released
Bike stalls when letting out clutch
Honda VTX1800R Owner Manual service manual not owners
Honda VTX1800C Owner Manual
Jan 20, 2014 | 2006 Honda VTX 1800R Spec 3
Beeping Code 9
9 BARS: The parking brakes have a bad connection or have a failed solenoid, or any lever or switches that disconnect drive for pushing the chair manually may be pulled or switched.
Nov 23, 2013 | Pride Mobility Products Go-Go Elite...
Kymco foru mobility scooter seat wont lock .keeps swivelling
hi , this normally happens because you need to move the side lever while moving the seat , it will lock in place then moving the lever will allow you to turn the seat.
Regards
Jan 16, 2013 | Health & Beauty
Yamaha Radian stalling
Re dies when put in gear Road Star Forum Yamaha Road Star
Bike dies when put it in gear plz help
Yamaha YX600 Service Manual
OEM parts for Yamaha
http://www.badrad600.com/Radian%20Manuals%20-%20Complete%20-%20Printable/Radian%20Owner's%20Manual%20Clean%20Complete%20Final.pdf
Mar 25, 2012 | 1987 Yamaha YX 600 Radian
Hi, The brake light on my Kymco Hipster 125 (03) is not coming on with the brakes, however when I turn the headlight on to any setting the brake light activates. Have checked the switch at the front brake...
strange but true I had a similar thing after going into my front area, what I had done is put the correctly wired wrong bulb in the indicator and vice versa into the side headlight, not an easy thing to do considering the two are physically separated but that's me, so then my side light was acting as indicator and my indicator was on constantly, in some way could you have done the same thing?
Jul 06, 2017 | 2003 Kymco Hipster 125
1700 Fortress Scooter won't go forward or backwards. The beeping is continual and the driving light comes on if you turn it on. The brake is in brake release mode. The battery is charged up? What is the...
Hi. Has the machine been in regular use before the fault occured? You say that the brake is in brake release mode, this mode is only ever used if you need to push the scooter by hand. It releases the brake on the motor, and also operates a switch to disable the controller from driving the motor. It does this because it would be to dangerous to drive the scooter with the brake disabled.
Move the lever back to its correct position. If it still does not work, then the disable switch might be faulty, or it might be a different fault such as a stuck brush in the motor.
Is this machine produced by shoprider ( Phisang ) of Taiwan.
Please let me know how you get on. Neil.
Jun 07, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Health & Beauty Logo
Top The Health & Beauty Experts
Motshidisimary
Motshidisimary
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
