Kia v6 2002 temperature gauge not working ,the car drives okay not overheating
The water level still okay
    Top Expert:
  • Washing Mach... Master
  • 49,191 Answers
Check wire to the gauge SENDER not coolant sensor
could be broken of fallen of the sender
Posted on May 07, 2017
Changed out water pump and thermostat and vehicle runs high temperature what could be issue?
Reasons the Temperature Gauge Reads High
If the temperature gauge reads high, it could mean your engine is overheating. Another reason your reading might be high is you could be losing coolant. A small leak or evaporation may cause your radiator to slowly lose coolant. A third reason your temperature gauge reads high could be because the thermostat is broken. If this is the case, you may need a coolant temperature switch replacement. The last reason the temperature gauge could read high is because of a water pump, or water pump gasket failure. If the water pump is malfunctioning, it may need to be replaced by a professional.
What to Do If Your Temperature Gauge is High
If your temperature gauge is reading high, it means your car is overheating. This is a very serious matter and you should never drive an overheating car. If your car starts to overheat, shut off the air conditioner and open the windows immediately. If this does not reduce the overheating, turn on the heater as high as it can go. If this still doesn't work, pull over on the side of the road, turn off the engine, open the hood carefully, and wait until the vehicle cools down. Never open the radiator cap while the engine is hot - coolant can spray and burn you. Once the vehicle has cooled, take the car to a mechanic right away so they can diagnose the problem. Cars are especially susceptible to overheating in hot climates, like what's common in cities like Los Angeles, Phoenix, Las Vegas, or Atlanta.
The temperature gauge is an important tool in your vehicle that shows the temperature of your engine's coolant. Contact YourMechanic and have your car inspected for overheating if it reads too high, as this can cause serious problems...
Reasons the Temperature Gauge Reads Cold
On most vehicles, the temperature gauge reads cold until the engine has run for a few minutes. If the temperature gauge still reads cold after the engine has warmed up, the gauge may simply be broken. Another reason the temperature gauge could read cold is if the thermostat in the vehicle stays open. With the thermostat stuck open, the engine can be overcooled, causing a low temperature reading. If this is the case, the thermostat may need to be replaced.
Oct 28, 2017 | Cars & Trucks
Temperature gauge for kia 2002 v6 is not working,the car drives ok not overheating
Either your coolant temp sensor is bad, or the wiring going to the temp sensor is faulty. Also, check your thermostat and your fluid levels. My bet would be on the coolant temp sensor though.
May 07, 2017 | Kia Cars & Trucks
Overheating
Have the Radiator cooling fans checked. There are Relays and the Temperature sensors activate the Relays which control the fans. The antifreeze level should be visible in the overflow tank.
The temperature sensors work off of the engine temperature. Usually 1 sensor controls the water temperature gauge or light and the other temperature sensor operates the Relays and signals the ECM about operating temperatures.
Aug 05, 2012 | 2002 Lincoln Town Car
Overheating
OVERHEATING CAN BE CAUSE BY MANY THINGS LIKE FAULTY THERMOSTAT AND FAULTY RADIATOR PRESSURE CAP,TOO MUCH WATER IN COOLANT SYSTEM NEED 50 / 50 WATER AND ANTIFREEZE.LOOK FOR WATER PUMP WEEP HOLE LEAK, IF COOLANT LEAKING OUT WEEP HOLE WATER PUMP BAD NEED REPLACING.CHECK FOR LOW COOLANT LEVEL, YOUR RADIATOR OVERFLOW JUG SHOULD HAVE COOLANT AT THE FULL COLD MARK IF NOT KEEP ADDING COOLANT INTO COOLANT OVERFLOW JUG UNTIL COOLANT STOP DROPPING AND FULL COLD MARK, IF OVERFLOW COOLANT JUG WAS EMPTY RADIATOR IS LOW ON COOLANT.WHICH CAUSE AIR IN COOLANT SYSTEM KEEPING THE ENGINE COOLANT TEMPERATURE SENSOR FROM BEING SUBMERGE IN HOT COOLANT WHICH TURN ON THE COOLANT FANS.WHEN ENGINE COOLANT TEMPERATURE GET CERTAIN SET TEMPERATURE LIKE 190 DEGREES THE PCM AND COOLANT SENSOR WILL TURN ON COOLANT FANS, IF VECHICLE OVERHEATING COOLANT FANS NOT WORKING EITHER YOU HAVE FAULTY ENGINE COOLANT TEMPERATURE SENSOR CHECK COOLANT FANS FUSE AND RELAYS. YOU CAN CODE SCAN CAR TO SEE IF YOU HAVE FAULTY PCM, FAULTY ENGINE COOLANT TEMPERATURE SENSOR OR FAULTY COOLANT FAN RELAY.IF COOLANT FAN AND ENGINE COOLANT TEMPERATURE SENSOR OKAY,YOU HAVE CORRECT COOLANT LEVEL IN COOLANT SYSTEM, THERMOSTAT AND RADIATOR PRESSURE CAP BEEN REPLACED, YOU COULD HAVE BLOWN HEAD GASKET CHECK ENGINE OIL LOOKS LIKE MILK SHAKE HEAD GASKET BLOWED ALSO WHEN HEAD GASKET BLOWED YOU CAN DRIVE CAR SHORT DISTANCE START OVERHEATING AND YOU LOOSE ENGINE POWER SUSPECT BLOWED HEAD GASKET.
Aug 04, 2011 | 1999 Oldsmobile Alero
I have a 1999 Oldsmobile Alero GL Sedan that is overheating. Where is the problem?
check coolant level, make sure car have half antifreeze and half water,if coolant level okay, car overheating when starting up driving is faulty thermostat and radiator cap.if car over heat while sitting in long line of traffic.your coolant temperature sensor could be faulty, or coolant fan fuse blowed or relay failed.hot wire cooling fan if it works, problem is the wiring or pcm, if every thing working okay.check engine oil if look like milk shake or you have a lot white heavy smoke coming out the exhaust, you have a blowed head gasket.
Apr 08, 2011 | 1999 Oldsmobile Alero
I have a 2004 kia sorento. while driving down the interstate at 75mph, i hear a ticking noise. all my gauges read normal. a minute later the ticking gets louder and the check engine light comes on. i...
Does the car have a normal oil level on the dipstick? The behavior is consistent with a broken timing belt except for the part about the temperature gauge going to the top which would indicate overheating or a faulty gauge.
Sep 08, 2010 | 2004 Kia Sorento
Overheated while idling in park for 5minutes.
your thermostat probably stuck closed.when you cooled it down,it opened again.change the thermostat.
Jul 14, 2009 | 2004 Kia Sedona
Overheating
is your coolant to level? you might be low causing the eratic gauge
Oct 07, 2008 | 2001 Kia Sephia
Washing Machines Logo
Top Washing Machines Experts
