Question about HP Garden
After two days on fuel tank and air filter pouring gas out of them I get my 5500 HP genartor pouring oil out of bottom motor ?
  • 5568 Answers
SOURCE: fuel tank leaking how to
I don't think you will have any luck sealing this from the outside.
Removing the tank (preferably empty), filling it with water and soldering all of the seams (if metal) or replacing it if of plastic.
This could be sloppy manufacturing showing up late, stress from being slammed underneath (is there signs of dents or scrapes?) or if metal, it might be rusting through which is pretty much a death sentence for it.
Pouring some (a cup or so) methanol, pure ethanol or a commercial product intended for that use, into your tank now and then will cause condensation to bond to the gasoline where it will pass though the system and out.
Posted on Aug 10, 2008
  • 37 Answers
SOURCE: Tractor not starting , I do not see any gas in fuel filter
Hi, can you tell us if your problem has been solve?
Posted on Nov 23, 2008
  • 126 Answers
SOURCE: gas pouring out of air filter
carb is gummed up from the old fuel turning to varnish and clogging the jets. while trying to start, its trying to inject fuel, but its clogged and taking the path of least resistance (coming out the air filter).
you'll need to drain the gas tank and remove the carb to clean it out. if unfamiliar or uncomfortable doing this, then take it to someone to do a carb cleaning.
Posted on Jan 31, 2009
  • 4 Answers
SOURCE: will start but then stalls and then gas pours out the air filter
float needle probly has some foreing piece of something stuck in it ,, allowing too much fuel in the carb,which floods out the engine
Posted on Apr 13, 2009
  • 9 Answers
SOURCE: Onan Generator stopped working in motorhome
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Posted on Feb 01, 2010
Mccullugh MCC1840 18" chainsaw. Gas pouring out bottom of saw. How do I get to the gas tank?
The fuel tank is part of the rear handle support body.
The fuel line to the carburetor goes into the top of the tank.
You will also find a return line from the air purge primer bulb. More than likely, one of these lines has broken or cracked. Gain access to some of the lines be removing the recoil assembly.
1) Remove the Air Filter and Filter Cover
(which you have already done)
2) Remove the recoil assembly to gain access to the primer lines.
Feb 14, 2017 | Garden
2010 F 150 oil light warning and wont accelorate
get you a gallon of marval mystry oil drain your oil and filter put a little mystry oil in your old filter rinse it out put back on and oil plug too fill with mystry oil crank truck let it run for 3 min let cool of drain put in new filter and oil if problem still accelorate and oil light still stays on you might have problems with oil pump if oil light goes out and still problems accelorating try changing fuel filter if this doesn't do the job also crack you truck up (if it is carberated carb) take air fiter off carb intake pour a little mystry oil in carb very slowly while running this helps to clean deposites due this for about little at a time you will hear motor sound like choking stop let motor catch up do this for about 3-5 min then pour mysry oil in till motor dies let set for 3 min start motor them put gas treatment (STP) in gas tank this should do the job if you have furl injestion put one cup of mystry oil in gas tank and one bottle of (STP) and atleat 6-10 gal of gas. if this doesn't do the job you may need to tale the truck to a spec.
May 27, 2014 | 2001 Ford Focus
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have 2003 envoy. when i take off it takes time to pic up speedcan does any body knos why?
it could be a simple as low oil, check your oil level and while your under the hood also check your air filter if your car can breath it cant go..if that dosent work it could be a fuel filter clogg from bad fuel..[water] in the tank. sometimes this can be cleared with fuel products like [heat].... just pour in the tank with gas next time you fill up.i hope this helps
Jun 01, 2011 | 2004 GMC Envoy
20 hp craftsman lawn tractor (2006) stopped running while mowing. tried to restart . ran for 2-3 seconds and quit. could not restart. fuel running free through filter all the way to carb. pouring fuel in...
I would take the bowl off the bottom of the carb.. Probably you have clogged up holes that let the gas into the bowl.Or either the needle is stuck up not allowing the gas to flow...That's why pouring gas in carbs would let it run for s few seconds....Also try fresh gas..Gas doesn't have led in it anymore..It don't last year from year...After grass season is over..Buy some from Lowe's or home depot..Pour it into your tank and let the motor run to get it done into the carburetor...Then the next year it will start
Jan 12, 2018 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do you drain the oil and gas out of this mower mtd 22' 4hp and how do you change the spark plug? do you need any special tools/thank you soooo much natalie
Drain plug for the oil should be under the deck next to the blade shaft. Usually a plug with a square head on the bottom of the motor. Loosen the fill plug and then remove the drain plug. Any time you go under there make sure you disconnect the spark plug wire so no spark can jump.
Gas is another thing. No fuel line as carb is part of the tank, so only way to empty is to .....
1) tilt the mower over and pour out the gas. Good time to change the oil and do it before you add the new oil.
2) unbolt the tank from the motor and remove tank carb and all a single unit. Then turn it over and dump the fuel. there are only 2 bolts holding it on so after you remover the air filter you can see them easily. Just remember how the throttle linkage hooks on.
May 21, 2010 | Mtd 22" Yard Machine Push Mower
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
2002 hayabusa throttle sticks cables are good springs on the stacks is good runs good after stacks is spayed an cleaned what keeps making it stick. Bad oil, Been running with no baffle in the exhaust...
Varnish builds up after awhile and causes this problem..gas can go stale in less than 8 weeks if the bike sits for awhile...Go to your local auto parts store and buy a can of Seafoam...pour 1/2 the can in on a full tank of fresh the tank down as fast as u can...pour the rest of the Seafoam in the next tank of will see an improvement...Would be a good idea to replace fuel filter after the second tank, any debris or sludge in the tank will be cleaned out also.. never run your bike without good air filtration, this is bad karma. K & N makes a good high flow filter. As far as motor oil...i recommend a full synthetic like Lucas... Mobil 1 or Vavoline...change it every 3500 miles.
Good luck, i hope this helps...please rate me a fixya.
Aug 12, 2009 | 1996 Suzuki RF 900 RS2
I empty gas tank and put new gas. could it be something is clogged?
It is a myth that sugar will mess your car up. Sugar does not dissolve in gas, it will just sit in the bottom of the gas tank. You will need to drop the tank and have it cleaned, and replace the in-tank fuel filter, but anything upstream of the fuel filter will be okay.
May 28, 2009 | 1999 Mazda Protege
Water in the fuel tank of my Zodiac dinghy with Yamaha 2001 50 HP
I'd add a little dry gas to **** up any remaining water and give it a shot
May 26, 2009 | Sport & Outdoor - Others
Garden Logo
24 people viewed this question
Top HP Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a HP Garden Expert? Answer questions, earn points and help others
