I have set box for channel,i can listen sound of different channel but i cant see video,there is black screen in top i see JUKE BOX written,how to remove that option to watch channel in my television.
SOURCE: rowe juke box
Put in service mode, type 55, then hold reset down while toggling 9 to cut on or off.
Should say free play on display.
Posted on Sep 26, 2008
SOURCE: Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Posted on Oct 17, 2008
SOURCE: Black square box pops up in the middle of tv screen.
It is most likely related to the Closed Captioning option on your TV. Go into settings and make sure that CC is turned off, or make sure it's set to CC1. What you are probably seeing is the "text" option included in the CC options.
Posted on Feb 15, 2009
  • 1779 Answers
SOURCE: black display box (nothing in it) in middle of screen
Someone has accidentally turned the Close Caption Text mode on. Go into your menu locate the closed caption section and just navigate to turn it off and that's it.... sometimes the remote may have it on there labeled CC.
Posted on Apr 08, 2009
GARYca
  • 672 Answers
SOURCE: TV has a black square box blocking out the channel
this is probably the closed captioning option, go into the menu and turn off closed captioning, its probably on text....Hopefully this helps
Posted on Jul 18, 2009
I have to resetup all of my tv and cable channels
menu on tv.. click add channels one by one ..add them manually /it should highlight them a different color.. also be sure that your box and tv match as to which channel they come through on.. I just hook my box up to the AV in the back.. and S-Video.. (waiting to get HDMI) but it sounds like your tv isn't "smart" so do it manually, one by one and edit them
I also suggest switching to DirecTV
Sep 03, 2012 | Panasonic Televison & Video
I need to tune my sharp tv to a set top box but am not having any luck. It only has an antennae connection and no AV channel. I have done an auto tune but cant get the set top box to work.
I have no idea what an antennae connection is. I assume you are talking about a Coaxial cable converter (large box that connects in line on the cable input). If this is the case, the box is override either channel 3 or 4. It either has a switch to pick which one of these to use or it is written on the box which one it uses.
If you are using a VGA connection (3 pins with 1 yellow, 1 white, and 1 red connector), then you have to find the AV channel. Every TV has one, unless it is like 4 decades old. If the TV is a few decades old, it may not have a channel called "AV" or "AUX". For example my dad's 25 year old TV uses 91 as the AUX channel. It is common for channels in the 90's to be used for this or channel 0. Best to just turn all the manually add/remove channels while the box is on. Then you can spot the right channel and add it to the listings.
May 09, 2011 | Televison & Video
What channel is the tv needed to be on to get cable, i push the wrong button on my tv then now is unable to get back to the cable channels.
Most cable TV systems that use a set top box or converter output on channel 3 or channel 4.
If you have HD cable service however, you probably watch on one of the A/V or HDMI inputs (Video 1, Video 2, etc.). Simply press the Video or A/V input selector, slowly & repeatedly until a picture & sound is seen and heard.
Apr 01, 2011 | Proscan 42LA30H 42 in. LCD Television
I have a Alba DVB-T set top box wont change channel
I think you most likely have a failed box problem.
Feb 17, 2018 | Televison & Video
I have tried to two different convertor box on my
Check your ratings settings, it almost sounds like youhave some ratings filter set so that if anything comes on that you wouldnt want kids watching it blacks out the screen.
Sep 23, 2009 | Hitachi 60V500 60" Rear Projection...
I've just bought a Altech AEC High Definition Digital TV Receiver and even though I'm not a blond female (sorry nothing against blonds) I'm finding it hard to understand the instruction booklet as to how...
Hi mrs Grumpy well this is a difficult task doing this blindly not knowing what you have there But I will try to explain the fundamentals.
First you have a coax (black cord ) from the external antenna. That goes directly to the antenna in on the set top box.
From that box you need a cable that has male and female plugs on black coax that goes from STB to the ANT IN of the Video recorder. Then from the VIDEO recorder ANT out Take that to the TV Now you might not have the right cables as Ins and Outs have different plugs on them You need some that are Male to Male and Male to Female The female plugs are O with and o inside them ( cant reproduce it in text) Males are an O with a pin inside them . so looking back at your connections From the wall to thje set top box is Antenna in is a female plug and Antenna out is a male plug. so check what cords you need to plug these together in the sequence I have outlined.
You will also need some different types of plugs that came with the STB that will be colored RED YELLOW and WHITE connect these from the OUT to the AUDIO/Video in the same color sequence to the recorder Than the next set of colored plougs from The recorders Audio Video OUT to the TV. Now it should all be connected cotrrectly You TV set TO AV should show the channel that is selected on the STB. Use the STB remote to change channel preference for viewing.
Get back to me if you need to cloarify anything.
Cheers Thank you for using FIXYA and please rate the help box.
Sep 23, 2009 | Televison & Video
Black box covers most of screen some channels, plus gibberish.
it is the closed captions on the tv. it is set to closed caption text. turn it off
Nov 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
Switching vcr channels
look behind your vcr there switch there [test signal]on and off turn to off the black and white bar will lost.
Oct 31, 2007 | Panasonic PV-7661 VCR
Televison & Video Logo
Top Televison & Video Experts
