Question about Cycling
Hello, I have a Btwin CAMELEO bike lock which I got from a friend in locked condition. My friend does not remember what the combination number is to open the lock. Can you please help me. Thank you.
  • Cycling Master
  • 1,189 Answers
Google "open combination lock"
Posted on May 07, 2017
I need instructions for my cameleo lock. It is open but I need to reset the code. Forgotten how to do that.
Usually there is a unit in the housing that you flip or spin in one direction to allow you to set the combination, then set it back into position so it doesn't block the entry for the male end, look on the cylinder portion of the lock for a mechanism to flip or turn inside the housing. That should be the answer
Please rate and comment, Thank You
Sep 01, 2011 | Cycling
I found 2 Kryptonite combination cable locks out of a storage box and do not remember there combination! Both are open! Is there a way for me to reset combination while there open? Thanks Denys
Probably not. But a simple solution for this is to turn the numbers and listen for a click when the tumbler locks into place. You' should be able to get the combination from both locks by doing this.
Aug 07, 2011 | Kryptonite Kryptoflex 1218 Combo Cable...
How do i set combination on a cameleo bicycle lock?
Pull back the wire completely, set to the new number and release the wire. The new code is in effect.
Jun 19, 2011 | Cycling
Aim unable to setup my b twin cameleo lock. Pose give me instructions for setting a new number
The above works I turned the inner chamber clockwise and set my code, thanks to Joe I now have a working bike lock!!
Jun 17, 2011 | Cycling
Lost combination for bicycle master lock. It has 229T sticker on it.
If you can remember an numbers in the combination you will just have to try all other numbers in combination until it opens
Apr 30, 2011 | Master Lock 8143DSG Combination Cable Lock...
I dont know how to open the lock its brand new????? They failed to give me instructions when they attached to the bike
My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
- I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
contained a pdf titled :
- Resettable Combination Cable
(red reset buttons inside)
which is not the cryptoflex 1218 but is compatible anyway.
dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
here are the instructions:
To set your own combination
Your new lock is preset to open at 0-0-0-5 at the factory.
1. Open the lock by aligning the opening combination
number to the Guide Points and pull out the Lock
Post. (Figure 1)
2. Push down the two Reset Buttons simultaneously
with thumb and forefinger, and turn counterclockwise
until it comes to a stop. (Figure 2)
3.You are now ready to turn the dials to set your
secret combination, such as a phone number, birthday,
4. After setting your secret combination, turn the
two Reset Buttons again by Thumb and Forefinger
clockwise until it comes to a stop and back to its
original position.
5. Verify your new combination before using your
lock. Insert the Lock Post all the way into the Locking
Port but do not turn the dials. Pull out the Lock Post.
Your lock is ready to use.
6.The reset operation is now complete. Repeat
steps 1-5 anytime you wish to change your secret
Oct 11, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
We bought a schwinn bike lock last year.....of course threw away the is locked (not on the bike) it possible t reset it somehow?
Try putting a lot of pressure as to open the lock on either end of the coupling. Turn the numbered cogs one by one feeling for the one that has the most resistance. The one with the most resistance is the one that is keeping it locked. Move this one forward or back until you can no longer feel resistance. Keep doing this for all the cogs. This may take some time.
After (if) you get it apart, look down the barrel as you move the numbers to find where the cogs are aligned as to put the lock back together with out locking it; i.e. the barrel is free of cogs. This should be all the same number, like 5. Once you have this number and the barrel free of cogs, there should be a switch at the end of the numbered barrel that you can flip up and over to the other side of the opening. Flip the switch, choose a new number that you can remember, and flip it back. This should be your new combination number. The lock should work now.
Good luck
Jul 05, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Schwinn bike lock
Try 0000, as it allways is a four digit combination !
Mar 18, 2009 | Locks & Locksmithing
Cycling Logo
65 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
