Question about Cell Phones
How do i disable voicto text feture permanatly
Disable predictive text
Check out the solution here: Enable Disable Predictive Text
Motorola Support
Apr 22, 2014 | Motorola Cell Phones
Rear a/c controls won't turn on
Have you checked the setup feture for the rear a/c on the front panel of the MMI display. You can lock out the rear panel from there, also if you have child protect activated a lot of features in the rear compartment are disabled.
Apr 24, 2013 | 2007 Audi Q7 4.2 FSI
While surfing the internet, my touch pad will lock up. The screen displays the touchpad and a finger with the red line over it. It looks something like the no smoking sign. How do I turn this feture off?
It's too easy
the sign appears says that you've disables the touch pad
You can enable it using one of the available methods:
  1. If there is a small button over the touch pad, just press on it.
  2. If not, use ( Fn + F7, or other key that have the same sign you saw ) usually, to toggle the touch pad status.
Please tell us your results
Good Luck
May 13, 2011 | Compaq Presario CQ56-115DX Laptop
2002 ford f 150 extended cab. Just replaced the cluster and theft light on and vehicle will not start.
chk your key is it clean and did you unplug your pats module under the colume or is there a module behind cluster near radio and you didnt plug it in the light is on because the security system is on and you did not disable it by putting key in the swtch this should disable the system or a fuse could be burnt as well are you sure the dash is exactly the same year there could be different fetures
Dec 30, 2010 | 2002 Ford F150 Regular Cab
Blackberry texting prediction problem
what exactly is the text are some general solution for text prediction
  1. options > auto text > edit > clear the with field ( this solution is used for instance if you keep type hr and it comes out as hour and you want to change that)
  2. options >auto text > new > enter word ( used to add a new word to auto text )
  3. options > SMS > disable auto text : YES ( used to disable auto text or test prediction )
Sep 11, 2010 | RIM BlackBerry Curve 8520 Smartphone
I have a xt r100 and it is curently in ftm mode how do i get it off ftm mode.
you need to take it in , it stands for Factory Test Mode. software fault. sometimes occurs when accessing bluetooth, telecom will send it to telegistics and get it fixed under warrenty as long as it isnt water or impact damaged,
Nov 19, 2009 | LG enV VX9900 Cellular Phone
I have a 1995 honda saber 32V,SRS light permanatly on ? Help
The only way you can fix this is to replace the driver side air bag it has lost its charge i have seen this many times with honda and have had this problem before myself.Hope this is helpful to you!
Mar 16, 2009 | 1995 Honda Accord
3250cemera was not supported
3250 cemara not supported general feuture not supported
Jan 11, 2009 | Nokia 3250 Cellular Phone
Code (22)
Dear Customer,
There are some vital informations and solutions regarding Code (22) error..
Code 22
The text displayed for this error code differs depending on the circumstances.
  • If this device is disabled because you disabled it using Device Manager, the following text is displayed: This device is disabled. (Code 22)
    Click Enable Device to enable this device. Solution button: Enable Device
  • If the device is not started, the following text is displayed: This device is not started. (Code 22)
    Click Start Device to start this device.
    Solution button: Start Device
  • If the device is disabled by a driver or program, the following text is displayed: This device is disabled. (Code 22)
    You can't enable this device because it has been disabled by a Windows driver. Solution button: None
This code means that the device is either disabled or has not started.
To resolve this error code, follow the recommended solution. For the third case, try removing the device in Device Manager, then redetecting it using the Add New Hardware wizard. If the problem persists, try a clean boot to rule out software interference. If the error persists, contact the hardware manufacturer.
Please Rate this Solution.. Thank You..
Jul 10, 2008 | Computers & Internet
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
