Question about Garden
My JD 3032E has a clogged fuel outlet line. tried vac. but cannot reach clog I can blow thru the line and un-stop line but clog always return's. what can I do short of removing the tank?
    Genius:
  • 2,653 Answers
The fuel pick up tube has sock like filter it will have to be replaced, should be a plate on the tank where the fuel gauge etcetera can be removed.
Posted on May 07, 2017
Fuel lines are clogged
flush them and replace filter
Apr 04, 2014 | 1986 Nissan Pickup 4WD 1986
Fuel fails to reach carb and prevents starting
Clean the fuel sock on the pump and connect a pressure line or air compressor to the fuel lines to blow out the clogged lines if that don't work then clean the jets to the carborator
Mar 23, 2014 | Vermeer 2006 Sc252 Stump Grinder
Fuel cant reach carburetor yp yamaha majesty
Hi, Escend always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Vacuum line to fuel valve clogged, cracked, pinched, bent, broken, or missing*
5. Faulty vacuum line switch/relay
6. Petcock clogged or diaphragm cracked, cut or torn*
6. Fuel line from the fuel valve/petcock to the carburetor clogged, cracked, pinched, bent, broken, or missing.
7. Vacuum lines to the mechanical fuel pump clogged, cracked, pinched, bent, broken or missing*
8. Faulty electric fuel pump and or wiring*
9. Fuel line from the fuel pump to the carburetor clogged, cracked, pinched, bent, broken, or missing*
10. Carburetor inlet fitting clogged.
11. Carburetor float and or needle and seat stuck.
12. Carburetor overflow line clogged, pinched, or bent.
13. Vacuum line from carburetor deacceleration valve not zipped tied*
* If equipped or applicable.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Need help with my scooter
2005 Yamaha Majesty Fuel pump replacement
Yamaha 2004 YP400 Service Manual
OEM parts for Yamaha
YAMAHA MAJESTY 400 Owner Manual
Apr 15, 2013 | 2005 Yamaha Majesty 400
2005 chevy venture van repeatedly blows fuel pressure regulators
You may be on the right track on the clogged or restricted return line. One thing though are you using E85 fuel?
Jun 14, 2012 | 2005 Chevrolet Venture
My cpi gtr 50 won't take in fuel i've cleaned the carb n the fuel but nott'n happens line
Hi, Kaleovidinha always check the fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
4. Fuel valve/petcock not in the on or reserve position.
5. Vacuum line to fuel valve cracked, broken, pinched, or missing
6. Fuel valve/petcock clogged or diaphragm cracked, cut or torn
7. Fuel line from the fuel valve to the carburetor or fuel pump clogged, cracked, pinched, bent, broken, or missing.
8. Fuel pump not working
9. Fuel line touching cylinder or head causing fuel to boil and vapor lock, repair by rerouting and wrapping line with convoluted tubing.
10. Carburetor inlet clogged.
11. Carburetor float or needle and seat stuck.
12. Carburetor not venting properly overflow line or bowl fitting clogged, pinched, or bent.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Fuel and Vac Line Tutorial
scooter not getting gas
CPI GTR 50 Service Manual
CPI Scooter Parts Racing Planet USA
CPI GTR 50 2009
Aug 27, 2011 | 2009 Cpi GTR 50
I have a craftsman h horse chipper/vac and i cant
Focus on the carburetor main jet.
On a float bowl carburetor, remove the bolt holding the bowl to the carb body. This is the main jet, clean the jet with spray carb cleaner, and also spray upwards into the center of the carb.
I have listed some basics to double check, not all may apply to your application. If you need more detail let me know. rwvanlue
Fuel Related issues that take a certain amount of time to appear
Depending on make and model of mowers:
a) Fuel tank outlet plugged (some have a screen filter,
some are 90' angle and plug with rust and debris inside the corner of fitting)
b) Fuel lines collapse when they are routed thru fasteners and between frame and seat decks
c) Fuel cap vent clogged
d) Fuel filter clogged
e) any fitting that has an orifice that can trap debris or rust will eventually become clogged
f) fitting on the side of the carburetor
g) some systems have a filter inside the line at the opening of the carb inlet
h) fuel pump
i) vacuum hoses to fuel pump
j) debris under inlet needle/seat on carb
Nov 13, 2009 | Craftsman 4 Cycle Blower/Vac
The vac function stopped.
Somewhere in the tube or impellor area, it is plugged with a piece of debris that is clogging the flow of air to the bag or outlet.
Nov 13, 2009 | Black & Decker Garden
My electrolux central vac outlets work on the main
You might have a plug or clog in the upstairs lines. for information on how to remove a clog in a central vacuum system see this article:
http://centralvacproducts.blogspot.com/2009/01/how-to-unclog-central-vacuum-system.html
Oct 24, 2009 | Electrolux Central Vacuum
BEAM Serenity Plus 2900 has shutdown
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. OK, there is a reset button on the unit but i think it could be that your vacuum could be clogged in the vacuum lines and that you should check all the inlets/outlets in your house with your vacuum hose - or get a vacuum cuff and go to each individual outlets and check the suction by feel - if the outlet is clogged you may have to call someone to unclogg it or by going to each oultlet the system may unclog it self -- or you can use a plumbers snake and be careful because the lines in a central vacuum are thinner than the walls in a plumbing situation or have it professionally unclogged by a priofessional. When you are using another vacuum to unclog the unit make sure the central vac is runing and to try to pull the clog apart from both directions. Below is a link to the factory for Beam and if you need a owners manuel for the Central Vac
http://www.beamvac.com/usa/
Sep 30, 2007 | Beam Industries 2900 Serenity Plus Central...
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
