Question about Vizio Televison & Video
The hdmi port of my vizio e231-b1 smart tv is not working. It displays either "No Signal" or "Not Support!" How can I fix this?
I have tried multiple cables and multiple devices. I am currently attempting a factor reset and it's now stuck on the time-zone selection menu for whatever reason. I have also tried turning it off and on again, and unplugging it and plugging it back it, along with attempting that with the hdmi unplugged.
    New Friend:
    Problem Solver:
  • 18 Answers
That message tends to result from a bad connection (perhaps the hdmi plug in the tv) or a source that does not comply with hdmi standards. This can often be the case when using a computer or gaming device for the signal source. Find a known good signal source and test, then if you still don't get a picture, switch the cable to hdmi 2 and try that one. Ports can go bad or wear out or get debris in them. Good luck.
Posted on May 07, 2017
Vizio e241i-b1 turns on, works for any input for 2-4 minutes, then screen freezes while long/continuous beep comes through speakers, tv then shuts itself off. can be restarted but does the same thing at...
Sounds like you have a bad capacitor. Likely overheating. Likely going to need service or replacement.
Google how to spot a bad capacitor. They pop up and get a brown dot in the center. They are easy to spot.
Jun 15, 2016 | Vizio E241i-B1 24-Inch 1080p 60Hz Smart...
No signal from hdmi inputs
If none of the HDMI ports work, then the main board is the problem. You can get a new one here :
Apr 26, 2016 | Vizio E601I-A3 60-inch Class Razor LED...
Vizio tv says no signal on any of the hdmi ports
Unfortunately, you fried the HDMI controller. Not necessarily part of the power supply "main board." (Not sure which board is the HDMI controller in your specific TV. It's usually a separate board by itself). Easiest workaround is to use the "Component" cable connectors. The downside is you only get 720P. However, most cable/satellite and _all_ antenna signals are only 720P anyway. Most people only see 1080P when viewing Blu-Ray discs. Aside from replacing the HDMI controller, the cheapest workaround for multiple source connections is to buy an HDMI to Component Converter A/V box, which allows you to connect multiple devices to one box with one set of Component cables connecting to the TV. Then select various "sources" via the box.
Mar 05, 2016 | Vizio E370VL 37 in. LCD HDTV
Model e231-b1
What is the problem you faces with this TV? If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 28, 2014 | Vizio Televison & Video
Dell HDMI cable no sound on Vizio TV
HDMI specification allows both video and audio to travel over a single cable, however, the signal source must offer both signals as well. There are instances wherein only the video is transmited. This especial true when using a computer as the source signal. In some instances a cable may be required to feed the audio into the video card. In other configurations this is acomplished through software in either the bios or control panel.
Sep 04, 2014 | Vizio M422I-B1 42IN LED LCD Smart TV Full...
Hi I have acer laptop, I have a cable one end is hdmi and the other side rgb, is there a down load driver so it will work. thank you
If you're trying to display output from the laptop to the Vizio you'd be better off using an HDMI to HDMI cable. The VGA port on the Vizio E320 only supports 640x480 resolution; you have to set your display output accordingly, usually in control panel. Using HDMI you're able to keep the signal HD, @720p. The E320 also supports 1080i, but you're not going to see all 1080 lines. If for some reason you're trying to go from the Vizio to the laptop it just doesn't work that way.
Jun 24, 2014 | Vizio E320VP 32" LCD TV
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
