Question about Garden
Wht r the valve adjustment spece on 18.5 Briggs's. an straton model 31n707
    Top Expert:
  • Garden Master
  • 51,218 Answers
.010" hot inlet
.012" hot exhaust
Posted on May 07, 2017
  • 15 Answers
SOURCE: need valve adjustment for a for a briggs and straton 31p777-0348-
Try .003-.005 on the intake, .005-.007 on the exhaust.
Posted on Apr 23, 2009
backwoodsctr
  • 169 Answers
SOURCE: I need a wiring diagram for a Lowe's riding mower
http://www.lakeviewpower.com/pages/parts/viewbybrand/default.aspx
here is a link to my website showing the electrical diagram hope you find this helpfull.....
Posted on Nov 21, 2009
  • 221 Answers
SOURCE: Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
Posted on May 17, 2010
mxc2
  • 146 Answers
SOURCE: no spark 10 hp briggs+straton
Remove the kill wire from the the back of the ignition module and test to see if you then have spark. If you have spark you would have a bad ground but if you still do not have spark then you may have a bad ignition module.
Posted on Oct 01, 2011
  • 1388 Answers
SOURCE: how do you adjust the idle on the Coleman 6250 Generator
There are many different models of Briggs used however simple methed is to find the governor shaft. Attached to the small shaft will be a lever with the governor spring and linkage that connects to the throttle. One end of the governor spring attaches to the lever and other is attached to either an adjustment screw with locknut or metal tab that can be bent. Increasing the pull of the governor spring on the lever will cause the engine rpm to increase. Bend the tab to allow for greater pull or adjusting the bolt with locknut. Make sure that the engine is not turning much more than 3600 rpm. Use a digital meter with Hz setting to set the output cycles at 60. When set at 60 cycles the engine should be turning about 3600 rpm which is where the engine develops max power.
Posted on Jan 28, 2012
What is the valve lash
try to google it and see if it will give you a diagram for it
Mar 24, 2015 | Briggs & Stratton 31N707-3026-G5 500cc...
How do you adjust valves
Check valve clearance while the engine
is cold.
1. Turn crankshaft counterclockwise until
piston is at top dead center on the
compression stroke. This prevents the
compression release from holding the
valves open.
2. Insert a narrow screwdriver or rod into the
spark plug hole as a gauge, then slowly
turn crankshaft counterclockwise until the
piston has moved down the bore by 1/4"
(6mm).
3. Using a feeler gauge, adjust
rocker nut to obtain the clearance.
4. Hold rocker nut and tighten the rocker ball
setscrew to the torque valve.
5. Check clearance again and re-adjust, if
necessary.
6. Repeat for other valve.
7. If twin cylinder repeat the above for the other cylinder.
NOTE: On some models, the nut and setscrew
are positioned above the push rod ends.
Mar 14, 2015 | Briggs & Stratton 31N707-3026-G5 500cc...
I have a briggs &straton intek 26 hp and the compresion seems to be not releasing.what can i do?
If the valves are adjusted too loose, the compression release will not work, and will make starting the engine difficult. I believe the clearance is supposed to be .005". If the clearance is too large, the 'bump' on the cam will not move the valve off its seat when cranked slowly, and compression will make the engine hard to crank over.
Jun 18, 2012 | Measuring Tools & Sensors
Riding lawn mower with 13.5 Briggs & Straton 28R707 motor dies when going downhill, changed needle valve, didn't help
If ther is not enough gravity feed from the tank ( fuel tank low in the tractor ) it will not allow the fuel to flow on gradients, try raising the tank with spacers under the fixings of the tank
Mar 28, 2012 | Briggs & Stratton Garden
Briggs and straton 5 horsepower overhead valve lawnmower 1978 is backfiring through carborator
Remove the top engine cover and check that the aluminum flywheel key is not sheared, then remove the valve cover and ADJUST the 2 overhead valves. They have to be adjusted periodically on ALL small engines with overhead valves.
Aug 13, 2011 | Garden
Briggs straton ohv on tiller , govener will not work, runs at high speed all the time, starter rope has become extremely hard to pull, will not spin engine.
The hard to pull, will not spin the engine issue could be because you need a valve adjustment. A valve adjustment is critical because it enables the built-in compression release on the Briggs OHV engine to function correctly and enable an easy start; plus of course, smoother running. Remove the valve cover and adjust those valves at 1/4" down past TDC on the power stroke. You WILL see a difference in the engine once you do the adjustment.. Here is a Briggs spec chart which has those values for their engines. Yours should be listed in the OHV engine section.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
Here is the Briggs recommended tutorial on HOW to adjust those valves. Scroll down this page to "Adjusting Overhead Valves"
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Servicing%20the%20valves/
May 22, 2011 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
