My washing machine drains the water all over the floor. Any suggestions?
    Top Expert:
  • Washing Mach... Master
  • 50,533 Answers
Broken hose under the tub
Posted on May 07, 2017
Washer will not drain TB displayed on panel any suggestions
Check pump filter. I have had this twice on my indesit washing machine. You have to take the front cover off the bottom and then unscrew the filter to check it. Be careful as it will gush with water if the drum isn't drained.
Check the drain pipe for blockage by disconnecting far end of it and lowering to floor level (in a bowl). If no blockage then water should drain out of the drum by gravity.
Apr 03, 2011 | Washing Machines
Whats wrong with our ge washing machine it keeps draining water,it is brand new just arrived.what do you think is the solutions to our problem. everything is being put together, we already install the...
make sure the drain hose is higher than the washer tub sounds dumb i know but if the drain hose is left lying on the floor going into a floor drain or something it will not fill up
Mar 23, 2011 | GE WBSR3140DW Top Load Washer
Machine stops in between its washing cycle ,displaying NO DRAIN please help
remove drain hose from drain and lay the end into a bowl on floor, if water flows from your pipe then your pipes in machine are clear. this could then suggest the problem would probably be within your pump. Can you hear your pump making a humming sound?
Feb 18, 2010 | Washing Machines
I have a GE Model WJRE5500g0WW washing machine. It is two years old, purchased new. After the clothes had spun dry, water was observed on floor. Drain tube checked and okay, not plugged up. Before I open...
Normally water on the floor can be from a few places. Mostly a faulty drain pump: possibly a tear in one of the pipes: rust in the drum: possibly water in the centre which comes from the bearings.(if the machine makes a racket when spinning, then i would look at the spin bearing collum). even concider drain pipe at outlet not running out onto floor. Either tilt washer back about 45 deg. to look underneath or possibly remove panel to allow a visual of the motor and components. See if you can pick up any indecationof water having run down from a particular spot. If so rectify. Hope it helped. .Ge washers not farmiliar to me but most problems are similar.
Sep 17, 2009 | GE WJSR2070B Top Load Washer
A used washer I am trying to hook up . . I have the drain hose going into the floor drain. The washer fills while at the same time draining. So it never really fills enough.
Washing machines need to be drained into a standpipe. This is a drain that is about 36" off the floor. The drain line on your washer will work fine if you have it installed in a standpipe.
by putting it down into a floor drain, you're not going to allow the machine to fill. The stand pipe will allow your machine to fill and still pump the water out during spin cycle.
Make sure there's a drain hose with a hook on the top.
k
Jul 06, 2009 | Washing Machines
When starting to wash water goes straight out of
The drain you are putting the drain hose into needs to be at least 30 inches above the floor. You probably have the drain hose to low or laying on the floor for this to be happening.
Jun 09, 2009 | GE WBSR3140DW Top Load Washer
The water will not drain out of the wash tub
The water drains out of the washing machine but the other day when I moved the washer I noticed that I could feel water sloshing around in the bottom of the drum but nothing is leaking on the floor.
Mar 21, 2009 | Kenmore Washing Machines
Drain old water
hi thanks for the question. to drain washer.put hose on floor in bucket. this will drain your washer thanks. for the question the appliance doc
Oct 04, 2008 | Kenmore 22062 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
