Question about Uniden DCT648-3 Cordless Phone
Phones won't work
I try to dial out on my phones and they all say out of range. They also won't ring when someone is calling. Please help.
  • 3 Answers
A) Ok first try to disconnect everything and connect all the batteries and cable back. Charge your batteries to full. Then if it still Out of range, do this with all your handsets.
- Disconnect the battery
- Hold the * and # key on the Handset and put the battery back without releasing the buttons. (now your in test mode)
- press the 2 softkey below the screen ( it's a factory reset, erase everything)
- You will see RAM/EEprom erase on the screen
-After the bip press end
B) OK! Now disconnect the power adapter from your base unit .
-Hold the memory button on your base and plug the power adapter at the same time. Then the base will bip to let you know that you done it correctly.
-after the bip press No.1 ( that's mean the handset 1 is de-registrer.
- Now De-register all the other handset by doing the part B again. But only changer the No.1 for 2 then 3 then 4.
C) Disconnect and reconnect everything and use your manual to register your handsets with the base and your done! Everything should be ok !
Posted on Nov 21, 2007
3Com 3102 phone dial tone but won't dial out
As long as someone hasn't been poking around in the phone system, this is a phone company issue. I have seen this many times and it has always been a carrier issue. Typically with PRI's or integrated access analog lines.
May 08, 2012 | 3Com NBX 3102 IP Phone
I bought your digital cordless phones two weeks ago and now we recieve no incoming calls because they do not ring although we know that they are ringing also we cannot ring out we hear the number being...
They're not mine or FixYa's phones, they are yours.
Are you hearing dial tone before you ring out? When a phone doesn't dial or ring, it's the first sign that it's not connected to a working phone line. Try a regular phone in the same jack first.
Dec 13, 2009 | Philips Lands Phones
No dialtone
If you use Dsl as a internet provider make sure you have the filters on each phone. If you use cablevision and have a wireless connection make sure you chage the phone to a 5.2ghz because you might have the wireless router with the same ghz causing a coflict. This will also create loss. of internet connections then you use the phone
Jan 19, 2009 | Panasonic GigaRange KX-TG2432 Cordless...
Hear other people on phone & phone no longer rings & voicemail not working
Could be line trouble. You probably need to make a service call.
Apr 03, 2017 | Vtech 2432 Cordless Phone
Calls automatically go to voice mail
When you pick up the handset you hear a stutter dial tone? Forwarding or DND might be on.
Oct 16, 2008 | Avaya 5400 Series 5410 Phone
My house phone rings when someone calls but we can't hear it ring nor can we get a dial tone to call out
The ringing you hear when you dial your phone number is not actually your phone ringing but a machine at the phone company designed to give you something to listen to while they connect your call. I would say that your phone number is working, just not at your house. You need to call repair to trace your phone line and get it connected properly. Good luck
Jul 17, 2008 | Lands Phones
Does not ring
is the ringer on the base or phone on? check that first.if that's ok, then plug a regular corded phone into the phone jack and see if there is dial tone.if there isn't any, try other jacks in the house. if still not working, call your phone company.
Feb 11, 2008 | GE 27998GE6 Cordless Phone
MD481 does not ring when incoming calls come thru and answer maching does not pick up.
try going to this link and looking for additional seetings for your phone or troubleshooting instructions-link is for complete user manual for your phone
Dec 20, 2007 | Motorola Mobility MD481 Cordless Phone
Machine dials during phone calls
please check if the machine is set to correct answering mode i.e. TAD/FAX ?correct it if otherwise. in case it is ok please check whether the DRPD mode may not be switched off ,pls correct it.. HAPPY FAXING HEMANT GROVER
Aug 29, 2007 | HP 1040 Plain Paper Inkjet Fax
Uniden DCT648-3 Cordless Phone Logo
391 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
