Question about Pool & Spa
Where does vaccum hose connect on onga spa pump
5 Suggested Answers
  • 201 Answers
SOURCE: vaccum hoses are missing. 1986 Nissan 720 4X4
truck normally has a vacuum hose routing diagram on under side of hood on drivers side.also look for metal tag on center of engine compartment fire wall which gives you a motor id @ and trk model # you can then know what engine vacuum diagram you need.i have a diagram for an 86 720 series Z24 carb engine that can be copied off of truck..chris
Posted on May 07, 2009
uspartscente
  • 717 Answers
SOURCE: I have a Lanark double
fill the tub with water and then turn the pump on. Get under the tub next to the pump and loosen the union on the discharge of the pump until some water starts coming out. If you have an air lock this will relief that and the pump should start pushing water to the jets.
US Parts Center
Posted on Aug 22, 2011
  • 111 Answers
SOURCE: air button line broken on 4381 onga spa pump
You could sleeve it but the best solution would be to buy a short length of that hose and two hose barbs. Tubing & Barbs
A foot of tubing would suffice, but with the relative low cost of the air button tubing these days it might be easier to replace the whole line.
Posted on Feb 02, 2012
emissionwiz
  • 79865 Answers
SOURCE: I just installed a onga pump to my spa (2nd hand) and the heater was working fine. Now everytime the heat light turns on it trips the power. If i turn heat right down everything works fine. Cheers
The heating element must be shorted out or the wiring to it is incorrectly installed..
Posted on Oct 20, 2016
We are trying to empty our concrete inground pool, how do we do this please, we have a onga ltp 750s pump
get a hose connect to the pump and the hose point to the nearest drainage ,
May 30, 2018 | Pool & Spa
How much zeoclor in an LS 24 onga
Does not matter on pool size, but on the filter tank size!
Follow Zeo's label instructions, as they may recommend a reduction of their product vs. Sand, say 80% of recommended sand amount. Good luck
Feb 23, 2015 | Pool & Spa
Does the onga spa master 4352 have a fuse or overload switch?
try to reset breaker if not blown check to see if there is a fuse after that probably a bad capacitor on motor or bad motor
Aug 19, 2014 | Pool & Spa
Air button line broken on 4381 onga spa pump
Feb 02, 2012 | Pool & Spa
How do i hook a vaccum up to my model 604 filter pump?
You should take your vacuum hose and plug it into the hole in the bottom of one of the skimmers. Fill the hose with water first or your pump will loose suction. I fill my hose by putting the head of the vacuum in the pool. Take the other end and hold it over a pool's discharge port (where the water comes back to the pool from the pump. When the air bubbles stop, put your hand over the end of the hose and move it to the skimmer and connect it.
That work for you?
Thanks fo your visit today.
Jan 30, 2011 | Intex Krystal Clear Model 635 Pool Filter...
When i put my hose in to vaccum i lose suction but with out hose it will **** your hand down the pump is workin great
Are you filling the hose with water before you put your hose into the skimmer? Put your vacuum in the pool - put the other end of the hose over a discharge ... when the air bubbles stop coming from the bottom ... , put your hand over the end of the hose and then stick the hose into the skimmer suction.
Jun 04, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Onga sand filter pumps sand in to pool ,just got re connected to new above ground pool
The lateral(s) are damaged and allowing sand thru and back to the pool. I have never dealt with that specific brand to know if the laterals come as one assembly or individual pieces. You'll need to contact the dealer you got the unit from or check online at http://www.onga.com.au/dealerlocator for someone in your area.
Dec 05, 2009 | Pool & Spa
The jets quit working when I prime and attach the vaccum hose
you could have a leak in the vac hose or a shaft seal on the pump, if there is a wet spot under your pump there is a good chance the shaft seal is BAD.... some pumps are so strong you can starve the PUMP for water, the trick is to set your valve more towards the main drain./ hope this helps.. i'm your local pool pump motor repair guy
Jun 20, 2009 | AO Smith 2 hp Swimming Pool - Jet / Well...
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
