Question about Whirlpool Washing Machines
Hi, I have whirlpool white mazic pro 700, top load machine. When I plug the power it is not showing any Display. machine stopped while it was in use. Please help me how to sort this problem. Thanks
  • Ambati Krishnamurthy
    Ambati Krishnamurthy May 08, 2017
    Hi RDjggar,
    I have already checked and found power supply is there.
  • Whirlpool Master
  • 2,320 Answers
Check power outlet to make sure there is power to the plug.
Posted on May 07, 2017
Do i remove the white plugs from the red and blue inlet valves?
'YES' if they are indeed plugs to stop general rubbish entering during pre-use but 'NO' if they are fine filters which are there to stop impurities in the water supplies entering!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Our Cabrio is showing "LD" in the display code and
you need to check your main drain pump for anything that may be restricting the water flow or stopping the impellar wheel from turning
Nov 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer keeps shuting off in the spin cycle and the code ob shows up.
Hi
Thanks for using FixYa. Error ob indicates off balance, if the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an “ob” for off balance. The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load. Press STOP/CANCEL to clear the display. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Display shows F1 top load cabrio whirlpool washer
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#*
May 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Heelo, during the spin cycle the washer stops and
Water not draining from the tub. Check for hose crimp ir clog. Here is your manual codes on page 19.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/8566930.pdf
Aug 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet Front loader mdl WFW8300SW00 will not start
I had a variety of error codes show up on my duet, and I'm not sure but I seem to recall a 31, but the most constant was 02. I took off the front cover, pulled the white plug out from the unit, put a bucket under it, unscrewed it and drained it. It may be the MCU is having problems because the washer got plugged up.
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint aqxxd169
take the top of the washing machine with the 2 screws on the back pull the top backwards. keep the power or ull get electrucated now ull see white plugs just simply press them in or if that doesnt work try
and click the circuit board back in
hope this helps u out
darren
Mar 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
