Question about The Toys
How can you tell if the helicopter is charging?
I need help because the helicopter remote keeps blinking when i charge it then 30 minutes later i remove the charge and the helicopter doesn't work.
    Sergeant:
  • 197 Answers
Well its either the charger or battery.... but by the sound of it the battery has failed... but just to check see if you can charge another battery with that charger or use a different charger on that battery....
Good Luck!
Posted on May 07, 2017
My helicopter will not take a charge the remote lights blinks and the charge plugs will not turn off
If I understand well you are trying charge the helli with the power switch "on" . Turn of the switch on the helli and try charge again.
Jan 26, 2015 | World Trading 23 Hercules Unbreakable...
Hi, the issue I am facing is that my remote is not able to connect to the helicopter. Earlier when I used to put the battery the light used to blink, now as soon as I switch on the remote it just does...
Helicopter should be powered off when charging. After fully charged (charging light as bright as it gets) and given 10 minutes to cool after charging, turn on helicopter first and place on level surface, this allows gyroscopes to sync up. Then, after making sure the main rotor control (left joystick) is all the way down, turn on controller, and quickly push left joystick all the way up (just until the blades move) and back down. This will link them. Also, make sure the antenna is still wrapped around the landing strut and not contacting any metal on the craft. And of course, good batteries in the remote, and ALWAYS let helicopter battery cool for 10 minutes after charging AND after flying. Also, NEVER fully drain battery, as soon as you cannot maintain altitude, land and power off. Fully discharging a Li/Po battery will weaken it severely, and sometimes kill it.
Please let me know if this helps, I love Syma helicopters, but they can be tricky sometimes...
r
Sep 04, 2011 | SYMA Toys industrial Syma S032 Ready to...
Hello i just bought a s032g from dealextreme 032 does not start up react to transmitter is zero i folowd the start protocol but noting anny ideas thanks
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Aug 13, 2011 | SYMA Toys industrial Syma S032 Ready to...
Syma S032 Transmitter battery lights blinks even when Brand new Alkaine Batteries are fitted
4) Power on remote.
r
Jul 30, 2011 | SYMA Toys industrial Syma S032 Ready to...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
4) Power on remote.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
My s032 remote does not respond unless it is right next to the helicopter there is no throttle control or directional control somtimes it will start but then shutdowns unless you put the controller right...
Did you, by chance mess with the antenna? It's is the wire that came wrapped around one of the landing skids. It must remain like this, and ideally not in contact with too much metal. Also, on my s032 I've noticed that even indoors and at close range, the antenna on the remote should be extended fully. Is the helicopter charged fully?
Charging/Remote linking:
4) Power on remote.
As a safety mechanism, remote disables itself if throttle is engaged at all when remote is turned on. Turn remote off, pull left joystick (throttle) all the way down, then try again.
hope this helps,
r
My sharpshooter and remote both turn on, but the helicopter does not react at all, what should i do?
I had this problem yesterday as well :)
My helicopter charged once worked and flew once for about 5 minutes. Then the helicopter stopped responding to the controller and it wouldn't take a charge. When I connected the remote to the helicopter the CHG light came on solid for about 30 seconds. This means that the controller is waiting to be plugged into the helicopter.
A couple of points to check before you go further:
1) make sure that the helicopter is turned OFF before charging!
2) When charging the red CHG light will blink.
3) When finished charging the red CHG light and the green Power light will blink at the same time.
4) After a certain amount of time both lights will stop blinking to save the batteries.
After taking the helicopter apart this is what I have found:
*The helicopter has a 140mA-H 3.7V Li-Po battery.
*The battery has a little board with 2 tiny computer chips. When the battery is empty these 2 chips will completely disconnect the battery. This prevents damaging the battery and this is why the helicopter stops responding when the battery is empty.
*There are two connections between the battery and the little board - a long connection which wraps one time around the battery and a short connection. My problem was with the short battery connection.
Solution --The little board has a short piece of foil which connects to another short piece of foil on the battery. These two pieces of foil are simply pressed together and then glued. In my case this connection broke. To fix the problem I removed the yellow tape and glue and used a soldering iron to solder the 2 foil pieces together. Make sure that you put tape (any household tape should be OK) back on the battery to prevent any shorts.
Dec 26, 2010 | Master Heaters Air Hogs Sharp Shooter...
My helicopter flew for a few seconds and then feel to the ground. It seems as if the controller does not work with the helicopter
Check your battery pack to see if the controller lost power or the battery pack in the RC ARF to ensure that, the copter can receive.
Dec 22, 2010 | RC ARF Falcon 40 Helicopter
Blinking remote light when charging
check the remote indicator censord
Apr 07, 2010 | Toys
Toys Logo
Top The Toys Experts
Paul Carew
Lawrence Oravetz
Are you a The Toy Expert? Answer questions, earn points and help others
