Question about Singer Sewing Machines
I can't move the needle clamp to change the needle on new Singer 2250 Traditional. Can you help?
  • Singer Master
  • 12,062 Answers
Here's the manual with the instructions:
SINGER 2250 Instruction Manual Inserting And Changing Needles
The screw that holds the needle in place also has a slot where a screwdriver can be used to apply extra pressure.
Posted on May 07, 2017
MarkDay
  • 111 Answers
SOURCE: The needle thread is blocked
Threading instructions for similar brother model:
http://www.mastersewusa.com/masmag11901_files/b114_471_721_771_XL711S_info_tg.htm
Possibly lever is to keep bobbin in place? If so, should slide left/right over top of bobbin.
Posted on May 14, 2008
ashish13
  • 75 Answers
SOURCE: singer 3116 - change the needle
I'm giving you a direct link to the Manual on page 82 of which is explained the procedure of removing the needles so you can attach new ones the same way...
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
Lemme know if it helps :-)
Posted on Feb 12, 2009
clyde2j2
  • 137 Answers
SOURCE: Replacement parts for New Home 222 combi (1983)
Try: www.sewingmachinepartsonline.com
Posted on Mar 02, 2009
bargainbox
  • 1388 Answers
SOURCE: my 8280 modle singer: I sewed a zipper for a
If you are not able to free this easily, you really should consider taking it to a service technician to look at it in case you do more damage to the needle bar and elsewhere trying to fix it yourself.
Posted on Sep 08, 2009
  • 980 Answers
SOURCE: can't get needle stay in the clamp ?
On the 237 there should be a very small piece of round metal that fits into the needle clamp so when it tightens it keeps the needle in the correct position, you may have lost that small piece of metal.
Posted on May 23, 2010
Machine fails to operate
Ooh, do not turn the handwheel in reverse...
First, make sure your machine has not been set to wind a bobbin. When that is the case, the needle is immobilized during bobbin winding so that you do not accidentally sew over your hand or something else. (Consult page 18 of the owner's manual.)
The machine is less than a month old. If there is something seriously wrong, contact the manufacturer. I should still be under warranty.
http://www.manualslib.com/manual/364482/Singer-2250.html?page=25#manual
Apr 30, 2016 | Singer 2250 Tradition
My needle is stuck in the plate
needle has bend remove power from mains supply and remove the needle then fit new needle
Aug 04, 2012 | Singer 2250 Tradition
Singer ultralock 14u64a jumbles thead on bottom
try changing the needle
rethread the top thread-- Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
also check the bobbin to make sure that it's threaded correctly
& inserted correctly into the bobbin case
Jun 03, 2012 | Singer Sewing Machines
How do I change needle
on the needle bar, there is a needle clamp screw, undo the the needle clamp screw & take out the needle, & place the new needle in correctly, if the eye of the needle faces you, then it must be put back in the same way,& pushed up as far as it will go, then tighten the needle clamp screw back
Aug 02, 2011 | Singer 3116 Simple
I am sewing stretch jersey and my needle keeps breaking with a terrible noise - I have a singer 2250? any ideas?
you need to use a stabilizer because the needle is pushing the material into the bobbin shaft and jamming it. Clean it out and oil your machine. Insert a new needle and totally rethread.
Feb 27, 2011 | Singer 2250 Tradition
My Singer Athena 09 drops the needle when ever the material is heavy. It usually doesn't break it just comes out of the part held by the screw. I need to buy stock in singer needles, as this happens way...
it sounds like the needle clamp screw is not tight enough or is stripped out
some needle clamp screws have a **** where you can put a flat screw driver in to tighten & if that doesn't work then you need to check on getting a new needle clamp screw
Oct 26, 2010 | Singer 8763 Curvy
Bobbin knotting & jamming on Singer 2250
Put the tensions back to the factory setting.
Re-thread the machine with the presser foot up and make sure the bobbin thread is feeding from the bobbin in the correct direction and through the proper guides.
Change the needle to one that is new and appropriate for the type of sewing that is being done.
If problem continues take the machine back for assistance if you purchased it from a sewing machine dealer. They usually do not take "returns".
Or, back to the store that it was purchased from if not from a dealer. You may have a limited time in which it can be returned.
Apr 18, 2010 | Singer 2250 Tradition
Changing the needle
Loosen both screws and wiggle the needles out. change the new needle As a rule of thumb, the flat side of the needle always goes towards the opposite side of the last thread guide. So on your machine, since the last thread guide is in the front of the needle bar, the flat side of your needle goes toward the rear. The needle threads front to back.
Jul 29, 2009 | Singer 2250 Tradition
Sewing Machines Logo
54 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
