Question about Garden
How Do I Obtain A Repair Manual GT48XLSi To Replace The Mower Deck?
    Sergeant:
  • 197 Answers
Posted on May 07, 2017
Belt is to long, is there a deck adjustment?
Jim, Double check to make sure you have correct belt for the deck and are installing it in the correct configuration as per manual or drawing on deck. Very few lawn tractors have deck belt adjustment, most do not, most deck belts have a spring loaded tensioner to take up the slack.
This could be some of your problem, the tensioner/idler pulley sometimes seize up and must be lubed up till they move freely, or your belt could be loose. Look in your manual or try google searching your make, model #, deck belt adjustment.
How to Change Riding Lawn Mower Deck Belt
Mower belt tensioner repair question to the Garage Gang
lawn mower deck belt routing Google Search
May 20, 2016 | Garden
When I engage the mower, the blades spin just fine but there isn't the same mower sound. The mower sounds exactly the same when engaged and not engaged.
If the blades are not installed correctly they wont cause the desired airflow and you wont hear the difference.
Apr 22, 2016 | Garden
I have a Toro model number 20622 auto start go forward and backward the blade won't turn it's like it's got a break on it how do I get this to work when I pulled the lever nothing happens
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
How to Replace Brake Pads on Mower Cutting Deck
Mower Deck Return Spring Replacement Craftsman Riding Lawn Mower Repair...
Apr 18, 2016 | Toro Garden
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
How to replace drive belt on sears 247.28904
If you have an Owner's Manual,it will inform you,in the Manual how to go about removing and replacing a tractor drive belt. There is a decal under the left or right foot board,informing the operator how to install the belt correctly. This is a long belt.that runs from the pulley on the Transaxle to the upper pulley on the bottom of the motor. This could be a hard repair to do,if the mower deck is installed. I have removed and replaced this belt,by lowering the mower deck all the way down. I would recommend,that you remove the deck,much easier.to replace the drive belt. This is also is in the Owner's Manual.under," How to remove the mower deck". Hope this answer your question. Sincerely,Brad Locke DTD. 12/03/15
Aug 06, 2013 | Sears Craftsman Tractor Mister
How to remove mower deck of grasshopper 720
Contact the manufacturer/distributor directly to obtain the information.
Nov 25, 2011 | Garden
I need to repair/replace the housing that covers the mower blades (part of the mower deck). How can I get a tech manual that has a remove and replace procedure? Do you have any pointers on the...
If you can give me the model number off under the seat i can get you a diagram and i will show you step by step on how to remove the shoot.. It shoue be a 917. something..
Jul 16, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
