Question about Ovens
I need a wiring diagram me to convert a T4 215 Thermostat to MP 101.
Simpson Oven
5 Suggested Answers
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Posted on Jan 10, 2009
tbreeze47
  • 3083 Answers
SOURCE: I have purchased an oven
My Adobe Reader isn't working on .pdf files, but this header on google mentioned your unit, so perhaps it has a wiring diagram:
http://www.google.com/#sclient=psy&hl=en&q=EFG-201+wiring+diagram&btnG=Google+Search&aq=f&aqi=&aql=&oq=&gs_rfai=&psj=1&fp=f66f1a25e5eaf8db
If you go to the following website, they have many diagrams and parts lists and wiring schematics for ovens:
http://www.appliancepartspros.com/
Just enter the model number and a page will come up if they have it.
Good luck, and hope this helps.
Posted on Sep 26, 2010
  • 103 Answers
SOURCE: Need wiring diagram for oven selector switch.logic-lbfanw12
call a sparky
Posted on Feb 03, 2015
Testimonial: "You muppet, get a life."
  • 44962 Answers
SOURCE: Need a wiring diagram for a Kelvinator De Ville double oven Model B305-1 with serial no. 2872. Top oven only work one element or what is the thermostat name and number for the top oven?
Request the wiring diagram directly from Kelvinator.
Posted on Feb 09, 2017
I have a simpson evolution 904 oven and the wiring diagram has been lost , would you have a copy
LOOK UP ON LINE TYPE IN SIMPSON EVOLUTION 904 WIRING DIAGRAM SEE IF YOU CAN FIND ONE THAT WAY. IF NOT TRY THE LIBRARY.
Jan 28, 2015 | Ovens
I need a owners manual for Simpson Concorde fan forced oven?
I recently helped a friend fix the oven in his secound home, turned out the timer was shot. But, in order to find this out, we had to pull the oven from the wall, and there was a wiring diagram in an envelope on the back of the oven. That is all that it took to figure out the problem.
Dec 14, 2014 | Ovens
Simpson evolution 804 oven element changed
possibly check continuity with power unplugged. that will give you an idea if switch is defective
Dec 24, 2017 | Ovens
Simpson wall oven 2001 wont turn off unless its turned to automatic.
Oven thermostat is faulty. needs replacing.
Feb 17, 2012 | Ovens
Bake element will not shut off at set temp.
You need to check the oven cycle relay,
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. In order to gain access to the oven cycling relay, refer to your owner's manual. Removing the back panel of the range accesses most relays, but some ranges locate the relay under the oven compartment where the utility drawer is usually located.
  3. Now you can test the relay using your VOM. First, label each wire attached to the relay and remove them from the relay terminals. Using your VOM's ohmmeter function, set the range to R x 1 and touch one test lead to the terminal marked L and the other test lead to terminal H2. There should be NO continuity. Next, test the terminals marked H1 and H2. Again, there should be NO continuity. Finally, test the S and R terminals. Continuity should exist between these two terminals. If your relay does not pass all these tests, it is defective and should be replaced.
  4. To remove the relay, undo the two screws securing it to the range and replace with the correct new relay. Refer to your wiring diagram and labeled wires to ensure that the wires are on the correct terminals. Now replace the back panel or drawer and test the oven.
Then you check the oven thermostat: When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
Hope this information helped you.
Jan 14, 2011 | Whirlpool RBS275PD Electric Single Oven
Wiring diagram of a Satchwell type70th thermostat switch
need wiring diagram for defy gemini petit chef oven switch
Dec 07, 2010 | Ovens
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Simpson oven 736 evolution turns itself on briefly then turns off
sounds like you have a control board problem
Jun 12, 2009 | Ovens
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Ovens Logo
29 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
