The fluff or ?? filter has come unclipped and is down in the machine. How do we get it out.
2 Suggested Answers
SOURCE: locating fluff filter on aeg washer/dryer
I have the same problem with mine. There isn't a fluff filter that you can get to easily. When the engineer came to fix something else he showed me this big tube thing inside the machine that had the inside coated with fluff. The machine wasn't very old and I only use the dryer for underwear (apparently towels make it much worse). So ... you'll have to get someone to dismantle the machine to get to the fluff. I was wondering if it is covered by the guarantee because it is ruining my washing.
Posted on Mar 14, 2010
Does this machine have a fluff filter? Ive never had a washer dryer before. Always had a fluff filter in my dryer
I've never heard of a fluff filter but I know it has a lint screen that needs to be cleaned at least every 3rd load or so for peak performance.
May 02, 2016 | Washing Machines
After washes it displays check detergent. some washes are also not spinning properly and cloths are still quite wet. Can you help I have a miele gala grande w 3000
Hi dear.
Basically you can check fluff filter otherwise you may need to have a technical assist. Fluff filter located on front LHS bottom corner of your machine.. Open plastic cover. Place small bowl under fluff filter area to collect about 2 Lt of water. Slowly turn fluff filter anticlockwise to let it drain remaining water in there.. Then remove it and check for blockage. ( Step by step You can get full instruction from your machine's user manual on cleaning and care section.) If that does not solve the issue you may call Miele to assist you or local repairer. I hope that helps.Thanks.
Jan 16, 2016 | Miele Washing Machines
Is there a filter to catch fluff during wash?
How to Reduce Lint in Laundry - Home Ec 101
www.home-ec101.com/how-to-reduce-lint/
Sep 23, 2010 - I clean out the dryer lint trap every time and that doesn't seem to matter. ... If your washing machine is older, there is a chance that it has a built-in lint trap. If this is the case and ... Follow the directions for cleaning the lint filter.
Washing Machine Pump Filter - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 8, 2013 - Common problems and faults with a washing machine pump filter. ... a pump filter to protect the pump from a build up of lint, and obstructions such as coins. ... towel to catch water and don't take it out at all if the washing machine still ... If you can't see any blockage, or there is just the odd button in there that ...
Is there a filter to catch fluff during wash? - Fixya
www.fixya.com/support/t26006809-filter_catch_fluff_during_wash
3 hours ago - Locating fluff filter on aeg washer/dryer . After using the dryer facility the following wash resulted in garment containing patched of fluff ...
How To Clean Your Washing Machine Filter - YouTube
Dec 13, 2015 | Washing Machines
Electric dryer overheats
Fluff blocking filter or if condensor prob heat exchanger is fluffed up in front on bottom unclip and pull out
Jul 15, 2015 | Estate EED4400WQ Dryer
How do I clean the filter on the Novotronic W 310 Miele washing machine
Cleaning the fluff filter and pump
Check the fluff filter initially after 3 - 4 washes to ascertain how often it is likely to require cleaning. With normal cleaning approx. 2 litres of water run out.
If the drain outlet is clogged, more water will be retained in the machine (up to 25 litres).
Caution: if laundry has been washed at a high temperature,
water draining out of the machine will still be hot!
Take the (yellow) filter flap opener from behind the detergent drawer facia panel. Open the flap.
Place a dish under the drain fixture. Turn the fluff filter lid round 2 - 3
times. Do not take it right out.
With large volumes of water when the dish is full, screw the fluff filter back into position and empty the dish before repeating the procedure.
Once the flow of water ceases, remove the fluff filter completely and
clean it.
Remove any foreign bodies (e.g. buttons, coins, etc.) and fluff.
Turn the impeller by hand to check that it is free to rotate. Any foreign objects causing an obstruction should be removed.
Clean the inside of the fluff filter housing. Remove any deposits of lime scale and detergent or foreign bodies from the thread of the filter housing and filter unit (as these objects can cause a leakage
of water). Put the fluff filter back and screw it in firmly.
Cleaning and care
To clean the water inlet filters
The washing machine has two filters to protect the inlet valves. These filters should be checked every 6 months or so, or more often if there are frequent interruptions to the water supply.
To clean the filter in the union in the open end of the inlet hose:
First turn off the stopcock.
Unscrew the threaded union connecting the free end of the inlet hose to the stopcock.
Remove the rubber seal from the recess. Using pointed pliers, take hold of the plastic filter bar, remove the filter and clean.
Put the filter and seal back in the reverse order and reconnect the
hose. Turn on the stopcock and check the connection is watertight.
Inspect the inlet hose which is subjected to high pressure while the machine is in operation. The hose should be replaced if there are small cracks in the surface, or if it has been otherwise damaged.
If replacing the inlet hose only use a hose able to withstand pressure up to 70 bar. Miele's own hoses meet this requirement.
To clean the filter in the water inlet valve:
Using pliers, carefully loosen the ribbed plastic nut on the inlet valve,
and unscrew.
Use water pump pliers to withdraw the plastic filter by the bar.
Clean, put back and secure.
The two filters must be put back in place after cleaning.
Mar 08, 2015 | Miele W310 Front Load Washer
How do i find the fluff filter
usual places are:- the inside of the door or inside the drum at the back. The fluff will look formed and like it's some sort of filter. if it pulls apart easely then its the fluff.
Sep 30, 2014 | Washing Machines
Locating fluff filter on aeg washer/dryer . After using the dryer facility the following wash resulted in garment containing patched of fluff .presumably from previous drying task.Is there a fluff filter...
Feb 09, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
ASKO T780 dryer automatically shuts down after aprox. 20 minutes
Check sensor for fluff. We have asko tumble drier and have had to clear this of fluff many times. Take bottom panel off, as if removing filter to clean. Located on left hand side is a plastic cover, grey, secured by one security head screw. Once screw is out carefully remove circular cover uncliping clips. Inside is a sensor with a plastic cage around it, about size of one pence piece, clean fluff out with toothpick for example. This should do the trick. Good luck.
Feb 13, 2009 | Asko T780 Dryer
Asko T741 - Thermostat keeps cutting out
Ken from Mecheltec suggests removing condensate sump and pump assembly and servicing it. Clear condensate hoses from lint and debris then carefully reinstall assembly. You should be ok.
Oct 06, 2008 | Asko T741 Dryers
Hi there, i have recently purchased a maytag atlantis washing machine 2nd hand model MAV7750BGW,great machine only its leaving lint on cloths and i dont have a manual for it,can you please...
To my knowledge, on most (but not all) washing machines, lint/fluff are collected on the wash cycle and flushed down with the water during drain cycle.
Since your machine is a Maytag, it is different. On most Maytag washing machines, lint/fluff is collected in the center tube of the agitator. It wold be necessary to lift out said tube and thereafter clean it on a regular basis. Some other models have a lint filter near the top of the tub, which you need to slide out, clean off, and reinsert. If for some reason there is no lint/fluff filter in your machine, this page shows how one can be made.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 24, 2008 | Maytag Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
