Question about The Computers & Internet
How to fix baby alive 2007 , she is not talking. She has new batteries I see a reset button but I don't know how to get into the small hole to push reset.
5 Suggested Answers
SOURCE: Put new batteries in the
Got the Black one and have the same problem..in try me it worked fine now it wont do anything...I wonder if the white ones work? LOL
Posted on Dec 26, 2010
  • 118 Answers
SOURCE: Hi i just want to
How old is he ?
Posted on Jul 29, 2011
rob924343
  • 15 Answers
SOURCE: 2007 nissan altima was in a small car crash put a
where was it hit? a lot of cars have safety feature so that when it is hit it automatically shuts fuel off to prevent fire. if this is the case most are in the trunk under the cover. all you have to do is hit the reset button
Posted on Apr 21, 2014
AndrexT
  • 19004 Answers
SOURCE: My striaght talk phone is not working. & need one.Can you send me a new one,please ? I have a small baby
sure no problem, contact them direct
https://www.straighttalk.com/wps/portal/home/support/contactus
Posted on Apr 11, 2017
My bushnell forcaster can not locate signal have tried different locations . worked prior ?
On many of these units there is a reset button or a small hole that can be pushed in with a paperclip to reset the unit after battery change.
Jan 04, 2015 | Bushnell Optics
After I changed a battery on R0614ZM TERNER watch, the display went berzerck and then blank altogether. Any ideas at all?
Some watches have a "reset" button or combination of buttons that must be pushed to clear all the electronic registries on the watch's little computer after you replace the battery. You might try taking off the watch back and seeing if your watch has this requirement. Even then, it's not always a perfect solution. Last week, I replaced the battery in a watch that had been dead for some time. The watch appeared to come alive again when I put the new battery in, but when I pushed the reset pin (on this movement, it was on the watch movement itself, next to the battery), the entire watch went dead. Nothing I did would wake it up. I removed the battery, waited 30 seconds, then re-inserted the battery. Problem solved; the watch powered up, and I was able to set the time and access all functions again.
On some digital watches from the 1980s, after replacing the batteries, you were supposed to push and hold all the external buttons for a few seconds to reset the watch. I don't think manufacturers still make watches that respond to this, but it is easier to try than taking off the back and re-installing the battery.
May 10, 2011 | Watches
Put new batteries in the bouncin baby alive and it only works for a second AND only on the try me switch, not the ON switch. Batteries are in correctly
Dec 25, 2010 | Hasbro Baby Alive Bouncin Babbles Baby...
Pantech matrix turns off when I push the period or backspace button when texting. I have reset phone by removing battery and sim card-did not fix. It is an intermittent problem
Try your reset button. It is around or under the battery. It is usually a small hole. You might need to use the end of a paper clip. If this fails, see your provider.
Dec 05, 2010 | Pantech Matrix Cell Phone
Don't know how to re start Frankling Spelling Ace Model SA206S
straighten out a small paper clip and use that wire to push on the reset button.
Apr 16, 2009 | Franklin Spelling Ace SA-206S
How do you change the batterys in hasbro cosmic catch ball game
The "push" button has a small hole on either side. there is a small screw at the bottom of each hole. Use a small philips head screwdriver. Once you have loosened the screws, this whole "block" of foam will come out of the ball and you will see the battery compartment.
Dec 27, 2008 | Cosmic Pet Hasbro Cosmic Catch Game
How do i reset my mp3/mp4? if he keep saying that it has no files on it but when i plug it in to the pc it says i still have files on them
get a led pencil and on the backside where it says reset put ur led pencil in there and push. and it will get on a blue screen and i guess u just let ur battery die so u can charge it again to fix it. but i dont noe if ur songs get lost. thats all i got for now
May 31, 2008 | Samsung YP-K3 MP3 Player
HP Ipaq hx2490
hi,
thats no problem, i got one of these little babys.
Nice piece of kit.
Underneath, small hole on the side by the Battery.
Use your stylus, push button. Hard-Reset.
Let me know if this Works, ****Before you rate this Solution****
Mike @ compurepair.
Feb 28, 2008 | HP iPAQ HX2490 Pocket PC
Alternate way to power the dash
This is extreme, but my Dash phone is alive again. After pushing the power button HARD! for an hour, I broke the button, and pushed it inside the phone. I ripped the button out of the phone with a knife, and carved away the plastic so I could see the circuit board inside. (about a 1/4" x 1/4" hole). Looking in, there are 2 empty holes in the middle -the former mounting legs for the button. To the left are 2 leads (solder points), to the right there are 3 solder points. Using a screwdriver, I jumped (made a connection) with the 2 leads closest to the edge of the phone...ie: 1st solder joint to the left of the holes, and 1st solder joint to the right of the holes, and it powered up. I will cover the hole with black electrical tape. I build prototypes for architects for a living, so this is a successful solution.
Nov 02, 2007 | T-Mobile Dash Smartphone
Computers & Internet Logo
22 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
