Question about Health & Beauty
Cant get pressure reading ,error 2 keeps comming up
  • 23 Answers
Robert You need to be more specific about what type of Pressure reading, and for what Item of medical equipment. Is it for your blood pressure cuff with a manuel knob pressure tighter? Or is it an Electronic one? I know about the knob ones, and sometimes you need to get a new knob by buying some old one that you will find in the thrift stores, or if it is for an electronic one. It is best to buy a new one. Let me know if I can help you with this if I am correct. Good Luck in your search for the anwer.
Posted on May 07, 2017
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
What is the meaning of scv motor circuit in toyota rav4
meaning ok you dont have a FSM book like asked in the other post.
why not learn to google and ask simple basic questions
here is the first hit.
http://www.baileysdiesel.com/on-highway/diagnosing-common-rail-diesel-faults-suction-control-valve/
he talks like a machine gun but the words are all there.
its just a fuel pressure reg FPR, but is for common rail.
and runs at huge pressure and is motor controlled
do not get hurt playing it and the high pressures.
just replace it, and pray. (DIY mode)
but keep in mind you never said why you were looking here
curious?
or got DTC errors. what?
lean to post question in a form of a job, or symtoms
we cant help teaching basics, use google or better
read the toyota OEM FSM factory service manual
read that page, on Fuel rail ops.
Feb 14, 2015 | Toyota RAV4 Cars & Trucks
Flashing F and H didn't complete cycle and cant unlock the door
F and H error code on the washing machine means:---
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Try this possibilities to solve this problem:--
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation.
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch.
Verify there is not a siphon problem.
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU).
Check all hoses for possible leaks.
Verify pressure switch operation.
Verify flow meter operation.
Verify CCU operation.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting System Error 0A0000 00000002
The error indicates low air pressure to the ink supply station. There is either a leak or the Air Pressure System (APS) is bad. Check for ink inside the rear door to the Ink Supply Station (ISS) and at the print head locations at the carriage.
If there is ink leaking at the ISS, replace the ink cartridge that is leaking. If there is a leak at the print head, replace the ink tube system. If there are no leaks, replace the APS. See the following link for parts: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Apr 14, 2010 | HP DesignJet 1050c InkJet Printer
My console freezes up at the end of every online COD2 match I play.
This same exact problem i have. This is due to either:
A: Your system is standing vertically up.
OR
B: It is on the floor of a carpet and is collecting dust.
They both lead to the same thing.
This error happened cause IF YOUR PROBLEM WAS A :the blu-ray disc player died because since u had your ps3 standing straight up it made it harder for the system to read the disc and the blu-ray disc died because of too much pressure due to that.
This happened cause IF YOUR PROBLEM WAS B : the system probably over heated or cant read the disc due to the dust. Buy a can of air and spray the vents on the side of your system. Then go and buy a cooling pack for your system. This will keep the system cool. Preventing overheating and pressure.
If this does not work, Call a SONY perfessional and have them take a look at it. This error code is called ERROR CODE 100810514. Thank you.
Jan 15, 2010 | Sony Playstation 3 (PS3) Console
My ps3 cant read any disks :'(
Jul 22, 2009 | Sony Playstation 3 (PS3) Console
Text messaging - cant send text messages
if you have nokia symbion phone so formate it and any brand you have for that you need to check sim center number or reset the phone
May 28, 2009 | Sony Ericsson W300 Cellular Phone
Error code can't read game disc, everything else works.
your disk reading lens is dirty or bad. you may try cleaning it with a q tip and rubbing alcohol. If it still does not work it will need to be serviced
Mar 10, 2009 | Namco...
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
Read disc error
You said the model is 77001?? is that the slim type ps2?? if it is try this troubleshooting step
if the console is lying down flat where the disc lid is at the right side, try applying pressure on the lower right corner of the lid, sometimes the lid's safety button gets worn out and it will give you disc read error if this solves the problem then the button really is busted, if you have technical background you try and change the button
Jun 06, 2008 | Sony PlayStation 2 (PS2) Console
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
