Can anyone explain error code 54 on brivis heating controller. And how to fix it or re-set controller
louislevel_2
  • 374 Answers
SOURCE: burn out circuit board
hi! there! replace the burn out circiut board,what ever you pull out the same thing you put back just be sure that has the same model and specification,calibrate and test overload protection,defective overload protection replaced to prevent any burn out,short circuited mostly came to burn those thing that's why imposing preventive maintenace schedule for this kind of large ac central unit is very much significant.mostly timer delay circuit malfunction on large scale unit supplying by three phase a/c source on central control panel board.when ever replacement occured try to put mark or list color coding of specific terminals to connect and isolate short circuit make possible to detect at once before installing the new one and make make record on this for future reference we have several cases like that after buying a new one and replaced still burn again,the common cases is that they did not find the cause of short circuit connection they just relay on circuit board burn out,so it better to make assured that every thing is fine before installing the new one.specially on supply source of circuit.,relay on diagram and manuals take and check all data source as reference this will be a great help.take all necessary precaution this should be done by qualified technical ac support,have a nice day and regards
Posted on Mar 31, 2009
  • 11 Answers
SOURCE: computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Posted on Jul 02, 2009
SOURCE: I have a Brivis Buffalo 20 heating.It continually
Check that all outlets are open, and also check that your return air filter is clean.
Posted on Apr 28, 2010
  • 3 Answers
SOURCE: Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Posted on May 05, 2010
SOURCE: Samsung AQV12VBA error cod displayed E5 54
Check the freon...
Posted on Jun 09, 2010
I have a Fujitsu asta18lcc the fault code says it is forced automatic switch welded can anyone explain how to fix this
Check error code is correct as this extremely rare. Possible fan motor fault instead. If error code is correct, replace indoor controller pcb.
May 28, 2017 | Fujitsu Heating & Cooling
Brivis error code 62 hi
Hi Matthew,
It would seem obvious to contact the manufacturer's customer support department. http://brivis.com.au/
Aug 01, 2015 | Heating & Cooling
Brivis zone
$900 seems like a lot for a new HSI and flame sensors :( 54 seems to be with the supply air thermistor. does the unit still operate with the error?
May 09, 2014 | Heating & Cooling
Brivis heating owners manual HE20i
I am having an error HO1 code#56 on my Brivis HE20i unit. It does not start. Initially had a code 55 and I did first press botton 1 followed by Fn and pressing 2 and 4 keys to make disappear the spanner. Can you help me, please?
Nov 01, 2010 | Heating & Cooling
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Apr 12, 2010 | Heating & Cooling
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Brivis Heater help
These Brivis guys and girls are a rip-off. They are only out to take your money. Then can easily ask you to do just as mentioned above. And pronto all works in 3 minutes to be precise.
It is just the power supply reset required due to a fult being detected, either caused by a very low setting on the controller less than 16 degs. or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
So, put the power supply to heater off first, reset the heater panel, press the button again to shaow EMS on and then set the heater to the required temp. after turning on to the heating mode. That simple! That is if it is the error 71 HI.
Jun 01, 2008 | Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
