How do I reset my IPod if it is disabled? - Audio Players & Recorders
Ipod is disabled, how do i restart it ?
The iPod Touch is a type of iPod that features a touch screen and can function as both a portable media player and as a pocket computer.
It is possible to password protect your iPod Touch so that you will have to enter a password every time you want to unlock the iPod Touch screen.
If you repeatedly enter the incorrect passcode, your iPod Touch will become disabled.
To unlock a disabled iPod Touch, you need to sync your iPod Touch device with iTunes on your computer.
Attach the iPod Touch data cable to the bottom of your iPod Touch device and attach the other end of the data cable to an available USB port on your computer.
Open iTunes on your computer and then select your iPod Touch device from the list of available devices on the left side of the iTouch window.
Click the "Restore" button.
If you have previously backed up your iPod Touch, you can choose to restore the device to the last back up or any saved backup.
If you have never backed up your iPod Touch, this process will restore your iPod Touch's factory settings.
Wait while iTunes syncs with your iPod Touch and restores the device.
iTunes will prompt you when this process is complete.
or
A hard reset restores your iPod Touch to its original factory settings.
This is useful when your iPod Touch is disabled and won't turn on or off, but all your data is erased.
Luckily, you can restore your data with iTunes after you've performed the reset.
Once you've performed the reset, your iPod is wiped clean and iTunes prompts you to restore the settings from your last sync.
Plug the iPod into your computer and wait at least 10 minutes.
This allows the battery to recharge in case it has drained.
This could fix your disabled iPod, if the problem was caused by a dead battery.
Click "OK" if your computer opens a "Connect to iTunes" alert box.
Depending on your version of iTunes, the message may indicate the iPod is in "recovery mode" and you need to restore the device.
ITunes opens and resets your iPod for you.
Unplug the iPod from your computer if you don't see the "Connect to iTunes" alert box.
Make sure the iPod is charged before you attempt the hard reset.
Press and hold both the On/Off/Wake button and the Home button on your iPod.
Keep the buttons pressed.
Wait for the Apple logo to appear, it may take 10 seconds or longer.
When you see it, release the On/Off/Wake button but keep the Home button pressed.
Release the Home button when you see a picture of a USB cable with an arrow pointing to the iTunes logo.
Plug your iPod back into the computer.
The iTunes "recovery mode" message will appear.
Click "OK" to complete the reset.
Dec 16, 2015 | Apple iPod touch
Apple ipod is disabled
You must reset the ipod device. You can do this by turning it off<hold down the power and home button for 6 seconds (or until the apple logo pops up). You can also reset it using iTunes.
Dec 26, 2013 | Apple iPod touch
Itouch disabled
You may reset or restore your iPod for a try, this can fix many general iPod problems. Or you may take a look at this iPod FAQ, it's informative.
http://www.mac-dvd.com/ipod-tips-and-ipod-faq.html
If it doesn't work, you can contact Apple technical support for help.
Dec 08, 2013 | Audio Players & Recorders
Ipod disabled want to reset.
there is no way to reset an Ipod fully without a computer. But if you go to settings>General>and at the bottom reset you can reset certain things on your ipod such as certain settings.
Nov 15, 2013 | Apple iPod touch
Reset disabled
Please again install i Tunes
Oct 26, 2013 | Office Equipment & Supplies
Password forgotten now say's disabled
Unlock a Disabled iPod
If you own an iPod Classic or iPod Nano, you can set a four-digit security code on your device and then lock it to keep other people from accessing it.
Disabling your iPod is a good way to protect the data on your device, but if you lose or forget the four-digit code, you will need to manually unlock it in order to access your music and other content.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC.
Open the iTunes application by using the dock icon on a Mac or the start menu on a PC.
Click on the name of your iPod under the "Devices" list in the main iTunes window.
Click on the "Sync" button to create a connection between the computer and the iPod.
Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer.
The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code.
Or
Hard Reset a Disabled iPod Touch
http://support.apple.com/kb/HT1808iOS: Unable to update or restore
Jul 30, 2013 | Apple iPod touch
IPod touch Digital Media Player: My ipod touch has disabled itself for over 21,000,...
plug it into your computer and start itunes and reset the ipod.
May 18, 2010 | Apple iPod touch
My ipod touch is disable.it tells to connect to itunes
plug in your ipod to your computer open up itunes and when your ipod appears under the devices section click on it and then under summary you can restore and reset the ipod
Oct 15, 2009 | Apple iPod touch
Disabled ipod touch
my sons ipod has a message that states ipod is disabled....connect to itunes. but when we connect to itunes it still is disabled????
can you help??
please e-mail me at lewis.michelle@stl.sysco.com
Feb 03, 2009 | Apple iPod touch
Ipod touch disabled
Try turning off your ipod, holding the home button, and plugging it in, while still holding the home button, until a picture of the ipod cable appears pointing to the itunes symbol. this will reset you ipod, and you don't need the passcode to make it usable again.
Jun 28, 2008 | Apple iPod touch
 Grubhead
Grubhead
