Question about Ovens
Will a door from another model fit my st George oven model FED-3. As a replacement door for this is no longer made
    New Friend:
  • 23 Answers
If you are low in cash to affording to get another Range/Oven. Then measure The Two sides, and then look on The Inside for where the hooks are placed that hold the oven door to the casing, and measure them as well from the outside corners, to the slot that the Hooks hold onto. From there Look for to see about the Light button pusher Place where it is centered and write all of this down in a pad with a pen. Then look on the back of the Range/Oven for the Make and Modle #'s and write them down. For you will need these later on. Afterward, if you're not picky about the outside color or design of the door. Then go to your local Goodwill and/or other Thrift Stores by phone, and while letting your fingers do the walking. You tell the head Thrift Store Main Manager what Make, Color, Modle
#'s & Measurements you have for all of the details that you need. Remember that you are recycling old worn out and misused Range/Oven for their parts. So if they give you the OKeDoekey on that they have that same model. Have them put it aside, and give them a timeline when you will be definitely down there to recheck it out and buy it for that part. The Rest of if You will have to scrap with a Recycle Center after You hire Your Brother or Best Friend can help you pick up the Range/Oven and take the Casing to the Recyclers for the amount of money you owe him for the ride and his troubles to helping you to solve your problem's.You might as well be taking out that Amazon.com Credit Card and buying a Used Range Oven through them. I hope this helps you Jackie.
Posted on May 07, 2017
HOW DO I REMOVE THE OVEN DOOR & HINGES FROM ST GEORGE UEOLAS ELECTRIC OVEN PLEASE
Most oven doors can be removed by opening door and pulling straight out. The hinges are attached to the oven frame not to the door. Some oven doors have screws that are attached to the hinges at the bottom of the door on the inside that need to be removed, then pull straight out.
May 16, 2016 | Ovens
Hi the temp on our st george oven, model ueo-8 has become unreilable?
if digital the replace the oven control / if dial then the dial is at fault . mm
Jul 12, 2010 | Ovens
Readout on control panel has faded so that you can hardly see it. Sometimes does not turn off oven causing overheating alarm. Have to turn off at power box. Is it expensive to replace control panel? St...
It is less expensive than replacing the whole stove if you do your self. Should be able to find parts a repairclinic.com. Hope this helps.
Feb 02, 2010 | Ovens
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
