Question about Johnson Boating
91 johnson 150 no spark at any plug - Johnson Boating
    Top Expert:
  • Johnson Master
  • 46,784 Answers
Ignition switch problem
corroded wires in the ignition system
ignition control module problem
Posted on May 07, 2017
Johnson 150 fast strike motor
Could be faulty kill switch,ign switch,stator,trigger switch,coil or cdi
Sep 06, 2014 | Boating
Have a 98 ficht/johnson 150 FI that will not start, it has good compression, fuel and spark. Is there anything else to check?
it could be spark plug gone bad or get you some sand paper sand tip of spark plug it get be geting bad connection with spark plug.
Feb 05, 2011 | Clymer EvinrudeJohnson Outboard Shop...
I have a 1978 70 hp johnson with the spark plugs out the motor spins freely with spark plugs in the motor is hard to crank, and sounds like it binding
Hi, with your spark plugs in you are turning the engine over against compression, thats why its harder to turn. The binding noise could be your piston rings, buts its difficult to say without further information. Sorry
Jul 15, 2010 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Dodge 1991 d 150 moter will crank but not satart
I had the same problem with my 91 dodge truck. I checked everything and found the problem to be in the fuel pump relay, it was not making good conection, spayed some WD40 on the conecters and have not had any problems.
Mar 21, 2010 | 1991 Dodge D150
I have a 1990 150 gt johnson. There is a problem with spark, sometimes all six cylinders work and then it will drop a few cylinders. checked coils by switching out with one that is working at the time no...
it might be the power pack but it could also be a much bigger problem . fixed one that had a hole burnt in the piston . ran good at times but sometimes it wouldn't get out of the hole
Mar 17, 2010 | Boating
Hi got a 1997 johnson outboard is a denso w24fsr spark plug ok for this motor cheers shaun
Stick with the NGK or try a Champion. A Johnson outboard is the only brand motor that will perform well with something besides a NGK.
Feb 28, 2010 | Spark Plugs BR4HS Plug 10/BX #3322
Boating Logo
51 people viewed this question
Top Johnson Boating Experts
kj henriksen
kj henriksen
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
