Finding out my wps pin on my television serial number G6B8MOA1E32009572
2 Suggested Answers
  • 187 Answers
SOURCE: Find my pin number
If I remember correctly some use 0000 as a default
some used 9999
Posted on Feb 03, 2015
Where do I find the WPS PIN
You will either fid the default WPS Pin on the back of your router, or you can log onto your router via its network IP address.
But you won't have to connect to your router via the wps pin. you can use the wireless password if you prefer to do so.
May 09, 2016 | Computers & Internet
Where is the wps button on a N 1 Belkin route?
Using Wi-Fi Protected Setup
WPS uses WPA2 (described below) for encryption. It does not
provide additional security, but rather, standardizes the method for
securing your wireless network. You may use either the Push Button
Configuration (PBC) method or PIN method to allow a device access to your wireless network. Conceptually, the two methods work as follows:
PBC: Push and hold the WPS button located on the back of your
Router for three seconds. Then initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WPS. The client has now been securely added to your wireless network.
PIN: The client device has a PIN number (either four or eight digits)
that is associated with WPS. Enable WPS through the GUI shown
below. Enter the client's PIN into the Router's internal registrar
(accessed through this GUI). The client will be automatically enrolled
into your wireless network within two minutes.
Oct 04, 2014 | Belkin (F5D8231-4) Wireless Router...
I am trying to connect my new wifi ext bt600 with no wps button on my router
Since your router does not have a WPS button, it is likely it uses a 9-digit pin number for WPS. The pin number should be on a sticker on the router or maybe in the router's setup guide.
Sep 19, 2014 | Computers & Internet
What is wps pin
Wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices.
WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either a button on the product or a an option on the wizard or utility screen.
Aug 15, 2014 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Where do I find the WPS pin number on the HP Officejet Premium
You can find the WPS pin number on the printer's on-screen display by following these steps (on the printer display itself):
1. On the printer control panel, touch the arrow symbol that's located on the far right.
2. Touch Setup.
3. Touch Network.
4. Touch Wi-Fi Protected Setup. Follow any on-screen instructions. (My printer doesn't have any real instructions on this page. Just some very brief bullets. This may be because my printer is already set up for WPS. On my printer, I simply press Continue at this point. That may be what you have to do at this point, too. But if there are actual instructions on this page, you may be required to follow them first. You can always use the back symbol to get back to any page, as needed.)
5. After you press Continue to leave the WiFi Protected Setup instructions page, you will be directed to the WiFi Protected Setup page. One of the options on this new page is PIN.
6. Touch PIN.
Your WPS PIN will be revealed!
Aug 06, 2014 | HP Officejet 6700 Premium E-All-In-One...
Can't find the PIN of this product
Good morning. There is no PIN to find on the router. You get the PIN from the Wireless client and enter into the router setup screen.
The wireless router supports two types of WPS, the WPS via Push Button and WPS via PIN code. If you want to use the Push Button, you have to push a specific button on the wireless client or in the utility of the wireless client to start the WPS mode, and switch the wireless router to WPS mode. You can simply push the WPS button of the wireless router, or click the 'Start to Process' button in the web configuration interface. If you want to use the PIN code, you have to know the PIN code of the wireless client and switch it to WPS mode, then fill-in the PIN code of the wireless client through the web configuration interface of the wireless router.
Here is the link for the Owners Manual for your router..
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N3_UM.pdf
Hope this helps..
Nov 03, 2012 | Encore ENHWIN3 Wireless Router
I didnt find the 8 digit pin number anywhere on the router of DIGISOL DG-BR4015N, please help me if u know dat number...
Login into 192.168.2.1 it will ask you for username and password default username is admin and password is password here click on wizard-> wireless-> WPS there you will be able to find AP pin
Sep 28, 2012 | Computers & Internet
Pin number
If you are talking about the WPS PIN code, you can get full details on how to set it up from the manual, page 127, under the WPS Settings.
You will need to know how to login to your router to get this PIN.
Jul 31, 2012 | Edimax Br-6428ns Wireless N 802.11n...
I have two laptops and want to set up a wireless network. I have the wireless set up but it isn't secure. When I go in to the Homegroups page it asks me for a 4 or 8 digit PIN number found on the router....
If you don't know it, you won't be able to automate your Wifi Protected Setup (WPS). The pin is a very specific way to prevent yourself from always having to remember codes, keys, passphrases, etc. Without it, its like saying that you want to to connect to Bank of America, and that it's just okay because you want it to happen.
The following is taken from the ESR-9753 manual:
- Wi-Fi Protected Setup (WPS)
WPS is the simplest way to establish a connection between the wireless clients
and the wireless router. You don’t have to select the encryption mode and fill in a
long encryption passphrase every time when you try to setup a wireless
connection. You only need to press a button on both wireless client and wireless
router, and the WPS will do the rest for you.
The wireless router supports two types of WPS: WPS via Push Button and
push the WPS button of the wireless router, or click the ‘Start to Process’ button
wireless router.
Jun 28, 2010 | EnGenius ESR-9753 SOHO Wireless Broadband...
Where and what is WPS pin from my belkin router? Im tring to set up a new kodack printer
You can find the WPS Pin number from the belkin router at the bottom you will have label it will be in the label.
This is a security for your wireless network
Regards,
Ayyasam
Nov 27, 2009 | Belkin (F5D7230-4) Router (587009)
Televison & Video Logo
Top Televison & Video Experts
