Where is the input button in the menu - Televison & Video
How do you change to hdmi video source
There are several ways to change your video input source for the E421VO. First: the lowest button on the side of the TV will cycle through the inputs. (The power button is the top button.) The original remote has the Input button to the left of the Zero button at the bottom left of the number area. With both just press the key multiple times to go through all of the inputs. Alternatively, press the Menu button and look for the Source sub-menu. Use the arrow keys to move to the chosen menu. (On the TV, the menu button is below the power button. On the remote, Menu is the button to the top right above the arrow keys.) If you are using a universal remote, you may need to find one that matches the Input or Menu functions for your TV. A different code may help if the remote has either button. Otherwise, you'll need a different remote.
The manual for the Vizio E421VO is available from Vizio's product site: http://www.vizio.com/e421vo.html . Click on the Support/Manuals tab. The direct link to the manual is http://www.vizio.com/documents/downloads/hdtv/E421VO/UM_E421VO.pdf . All of these options are shown in the manual.
I hope this helps.
Jan 17, 2016 | Vizio E421VO - 42in Lcd 1080p 60hz Hdtv
How to get to menu then adjust it to antena?
First make sure that an antenna is connected the coaxial input on the TV and the input is set to TV. There is an Input button on the top of the TV and on the original remote. On the remote, the Input button is below and slightly to the right of the 0 button. On the top of the TV, the Input button is the one closest to the Power button. You can toggle through the Inputs by pressing the Input button several times or use the up/down arrows and then press the Input button to select the input. (TV should be the top item in the list.)
Next press the Menu button on the remote, above and to the right of the arrow keys. (There is no Menu button on the TV.) Use the left/right arrows to navigate to Setup. Next use the up/down arrows to select CH setup. Press Enter. If you've set a PIN, you'll need to enter it. Use the up/down arrows to select the line Air/Cable, if you need to change the source of your signal. Press Enter. Use the left/right arrows to select your source. Press Enter to save the setting. Press Menu to exit. Return to this CH setup menu and use the up/down arrows to select CH Search and press Enter. If you are using an OTA antenna, use the left/right arrows to select Start and press Enter. Wait for the search to be completed. For cable sources, you'd need to select from Analog Search Start or Digital and Analog Search Start. Press Cancel and then Enter to exit the search.
Crutchfield has the manual for the LC-32D62U available from the product page under the Details tab: http://www.crutchfield.com/S-mhRC3OB2Fi4/p_284LC32D62/Sharp-LC-32D62U.html . The direct link to the manual is http://d2stobyut4u5rx.cloudfront.net/ImageBank/v20080124174400/Manuals/284/284LC32D62.PDF . The Input button use is available on page 30 of the manual. The channel search steps are shown on page 23.
I hope this helps. Please note, if you have an replacement universal remote, you may need to try multiple codes for Sharp TVs to get the Menu button to work. If your replacement remote doesn't have a Menu button or none of the codes work, then you'll need a different remote.
Nov 07, 2015 | Sharp Aquos Lc32d62u 32-inch 1080p Lcd...
When pressing menu on remote control I do not have a tv section listed to tune in channels
The TV channel settings Menu is usually only available when the Input is on TV. Look for a Source or Input button on the TV or the remote. Press this button and try to change to the TV source option.
Please add a comment with the make and model of the TV for additional information. (Unfortunately, many TVs don't let you change the source after pressing the Menu button and they don't always have a Source/Input button on the TV. Additionally, some replacement remotes don't even include a Source or Input button. For those with an Input button, you may need to try other codes to see if any will correctly work with the TV.)
Nov 05, 2015 | Televison & Video
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
How to get to input by menu on trutech tv model cr202tt9 august
If the TV has a Menu or Setup button at the front panel, you can enter its menu and can select inputs. If it has no such button, you must have remote control to select the inputs.
Jun 06, 2012 | Symphonic ST419E TV
I have programmed my remote to an older JVC television. everything works, but i cannot change the input from the remote. I have a ps3 hooked to the tv. anytime i want to play my ps3 i have to manually...
If the tv has an input button on the side it should let you scroll through all the inputs without having to go through the menu. Hope this helps.
May 24, 2011 | Televison & Video
How to enable the input of lcd
hi,
u can sellect input by following setup
1. Press INPUT. on remote
(A list of selectable sources appears).
2. Press INPUT again to select the input
source.
( An image from the selected source automatically
displays).
Each time INPUT is pressed, the input source
toggles.
If the image does not come in clearly from the external
equipment connected to INPUT 1 or 2, you may need
to change the input signal type setting on the "Input
Select" menu.
1. Press MENU to display the MENU screen,
and then press c/d button (on remote) to select "Option".
2.Press a/b button (on remote) to select "Input Select", and then
press ENTER.
3.Press a/b button (on remote) to select the signal type you
want to set, and then press ENTER.
4.Press MENU to exit.
just try these. need further help feel free to contact.
ok.
Dec 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Onscreen controls don't respond
You have five buttons at thee right-hand bottom of your screen (just under thee edge). They are (from
left to right) the Main Menu button, the Down button, the Up button, the Input button and the Power
button (under the light).
To adjust your screen press the main menu button. Once the main menu screen is up, toggle
through it using the Up/Down buttons. Once you see what you want to adjust, move over to the
right side of the menu by pressing the Input button. Now use your Up/Down buttons to highlight
what you want to change. Once it is highlighted, press the "Input" button again. Now use the
Up/Down buttons to adjust your settings.
Once you have adjusted the settings, simply press the main menu button to exit.
Sep 10, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
I have a blank acreen and only Spanish in the menu
Press the menu button on the remote anc change the language setting. Blank screen, you may have to do a full channel scan (also in the menu screen) to search for channels. Lastly, make sure the correct input is selected to the input being viewed ( if the cable is connected to Input A on the bacl of the TV then you need to press the Input button on the remote to select input A (these TVs usually have like 5 different inputs to choose from).
Jun 30, 2008 | RCA Televison & Video
Rca tv f27628
http://sci.tech-archive.net/Archive/sci.electronics.repair/2006-12/msg01203.html
Turn on the TV
using original remote:
Bring up TV Main Menu and select option 7 (TV Guide Plus Menu)
Select option 1 (TV Guide Plus Setup)
Find the MENU, GO BACK and Input button on your remote
Press the MENU Button then immediately:
Press the GO BACK button then immediately:
Press the INPUT button.
Note: It is important to press the Menu, Go Back and Input buttons quickly (within a second of each other)
Nov 11, 2007 | RCA F27628 27" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
