Question about Uniden Lands Phones
I have a uniden SS E35 + 1 and cannot find speed dial in the instructions. Is speed dialling possible?
One Wire
  • 126 Answers
SOURCE: Speed Dial for a Uniden Model DCT648-3
Do you have a copy of your owners manual? If not, here is a link to a pdf format version of it, from the Uniden website:
http://www.uniden.com/pdf/DCT648-3om.pdf
Speed Dialing
If you store a phone number in a speed dial memory location (10 locations: SPD1 - SPD0),
you can use the speed dialing feature. When the phone is in standby mode, press and hold a
number key (0-9) associated with the speed dial until the phone number appears and then
press talk/flash or speaker. The number stored in the speed dial (SPD1 - SPD0) is dialed.
Posted on Jan 26, 2008
SOURCE: Adding speed dial nos to uniden waterproof handset
I found the model no, on the Uniden website DSS 7805WP and down loaded the manual.. there were no instructions .. but i showed where the phone book icon was .. and once inside the phone book the process was the same as the handset that came with the answering machine.
Posted on Jun 19, 2008
SOURCE: lost instruction manual for uniden
i NEED TO KNOW HOW TO PROGRAM THE TIME AND DATE.
Posted on Oct 14, 2008
SOURCE: uniden power max 5.8 speed dial
Press and hold a number key (0-9) associated with the speed dial until the phone number appears, and then press talk/flash or speaker on the handset or speaker on the base. The number stored in the speed dial is dialed.
Posted on Jan 22, 2009
SOURCE: How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Posted on Feb 05, 2009
Why does the phone not call out ? It says the way the number is dialed doesn't work?
Did you read the instructions that came with it? I am wondering if you have to dial 9 to get an outside line if this is a home PBX unit?
The other possibility is that the phone is not set to tone dialling and is set to pulse. When you dial, do you her musical tones or clicks corresponding to the number dialled?
Comment back with Make and Model as a comment to this post.
Nov 24, 2015 | Lands Phones
I want to set speed dialing but do not have the operator book
Go to contacts or phonebook.
There find the options option and Select speed dialling.
Assign contacts to the respective speed dialling number....
Jun 15, 2010 | Lands Phones
Speed Dial
Select the model of the phone from the list at
http://www.uniden.com/index/manuals_results.cfm?cat=1
May 20, 2010 | Uniden Cordless Phone
NOTE:
warning.
Chain Dialing
number.
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
I want to change speed dial nos. don't have manual for instructio
You should be able to download the appropriate manual from
http://uniden.com/index/manuals_results.cfm
Jan 07, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Nokia 1100 Speed dialling
Press Menu, select Contacts and Speed dials. Select the key you want,
( to ) and press Assign. Select whether you want to assign to call or to
SMS. Select the name you want and press Select.
After the phone number has been assigned to a number key, you can speed dial
the number in the following ways:
• Press the corresponding number key and then press Call, or
• If Speed dialling is set to "on", press and hold the corresponding number key
until the call is started
Nov 30, 2008 | Nokia 1100
Jun 19, 2008 | Uniden Tru-Digital Expansion Waterproof...
Speed Dialing
Nov 30, 2007 | Uniden DCT648-3 Cordless Phone
Lands Phones Logo
47 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
