Question about Refrigerators
Model#gfss6kxass. Ice maker only makes ice about one time per day. Can hear clicking noise occasionally that seems like it's coming from ice maker. Water dispenser pressure appears to be ok.
  • 489 Answers
SOURCE: LG Ice maker
You may have a broken ice maker and it needs to be replaced. You will need to have a qualified LG technician assist you.
Posted on May 11, 2008
maklean
  • 1665 Answers
SOURCE: no water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    SOURCE: Kenmore Coldspot Ice maker is not working on our side by side refrigerator
    I have a kenmore coldspot side by side model # 106.53662300.
    The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
    Posted on Aug 30, 2008
    • 12 Answers
    SOURCE: Whirlpool side by side refrigerator, model # ED25PQ
    Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
    Posted on Dec 01, 2008
    jumptrout51
    • 3361 Answers
    SOURCE: ice maker will not dispense the ice
    The auger motor and coupling in the rear may be frozen and won't turn.
    Remove the ice bin.
    Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
    It will be difficult to move.
    If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
    Posted on Mar 23, 2009
    Why is icemaker making a clicking sound?
    Ice Maker Not Dispensing Ice ' ThriftyFun
    www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
    Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
    Ice maker making ice, but won't come out thru door
    www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
    If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
    Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
    Amana French Door Bottom Freezer Refrigerator making noise but not making ice
    hello sir
    if ur ice maker
    Makes no ice
    Jul 08, 2008 | Amana AFD2535DES French Door Refrigerator
    Every 20 seconds it makes a loud noise like a pump being activated
    Sounds like the compressor trying to start. Is it making any ice?
    Apr 05, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
    Howling noise
    Check the help link mentioned below:---
    Click the link:--
    Ice maker is noisy and not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
    These will help.
    Thanks.
    Nov 21, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
    Samsung refrigerator rf26v ice maker
    Check the condenser is clean and clear. Remove all fluff, dust or dirt from under and behind the unit
    Apr 23, 2012 | Samsung RF26VAB (25.5 cu. ft.)...
    Amana ARB8057CSR Bottom Freezer Refrigerator, Intermittent Quick Loud Noises Appliance history: Purch. 12/03. Replaced PTC relay 12/08. Water filter last replaced 3/10 (2-person household). Problem:...
    No-one posted a solution. I contacted the original solution poster who was very helpful.I hope this helps someone else better understand their refrigerator problem and get on the right track. Staffgage.
    Tweezb wrote:
    "you are right that cleaning under your refrig wont get rid of a "compressor knocking" sound. what it might do is to lower the amount of heat from the condenser coils and thus cause less pressure and stress on the compressor making it run easier and less likely to bang or knock when shutting off.
    if your coils were very plugged with lint and you have cleaned them, that will help but it wont "fix" the problem.
    inside the compressor is a motor and a pump, the motor is supported by 3 springs and they can stretch or break causing the motor to hit one side of the black outer can and cause the noise.
    that may be too technical, but its not something that can be repaired without replacing the compressor, at a cost of 700-800 bucks. most would not pay this as its not worth putting that amount of money into an older refrig."
    "think that you are hearing either a freon related sound or even just the sounds of the unit going thru defrost.
    how often do you hear the noise? just maybe once a day or is it everytime the unit shuts off?
    either way i would rule out the ice maker and water system as when the "shut off arm" is up then it is off and wont make any noise, or ice.
    keep the i/m arm up and then listen for the next day or two and try to narrow down when it makes the noise and frequency you hear it and then get back to me.
    it may not even be a problem, just normal operating sounds that cant be changed."
    Oct 20, 2010 | Refrigerators
    Water works on door but ice maker isn't making ice occasionally hear noise like trying to dump ice cubes but no ice
    the water valve located on the back of the refrigerator that the water line is connected to could be bad. if no water is coming to the ice maker then it shouldn't have any ice or water in the ice mold. if it is empty you can try pouring enough water in the mold to make ice cubes. wait an hour or so and see if the ice maker dumps the ice. if it does you probably have a bad water valve.
    if your ice maker has ice in it but had been making small cubes you should check to make sure you don't have a jam. small cubes could be from low water pressure or a blockage. if your refrigerator has a water filter it may be time to replace it if the water dispenser water pressure is also low.
    May 28, 2010 | Hotpoint HSM25GFRSA
    Our ice maker is making 5-10 cubes per day. Ice
    OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
    Apr 14, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
    Ice maker bar sticking at bottom now a loud grinding noise
    you can replace the whole ice make or remove the head and replace the cut off cam inside the ice make head..
    hope it helps
    Jun 20, 2008 | Frigidaire FRS26R4A Side by Side...
    Refrigerator is making a loid noise
    ** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
    Mar 10, 2008 | Refrigerators
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
