Question about Cell Phones
My phone drain power quickly. I have tried to turn off all apps and anything extra.
My battery drains very quickly, huawei g8. Which apps can i close from the huawei installed apps?
Facebook drains the battery. So i suggest you close that one. But to completely save your battery, you can get an app that completely does wonders. The app is called Greenify. Its very helpful.
Nov 12, 2016 | Huawei Cell Phones
Battery runs out fast
Many things can cause rapid battery drain. Ensure that you only have wifi enabled when you are using it, otherwise the phone will always be searching for wifi hot spots and this drains battery power. The same with bluetooth mode. If the phone is 4G capable, and it it turned on, it will search for 4G signals and use extra power. 4G uses much more power than 3G does, so if you don't need the extra speed, disable it when not needed. Lastly, if you are using your phone as a wifi hotspot for others, you are looking at definite battery drain there.
Apr 14, 2015 | LG Metro PCS Optimus L70 Prepaid...
Why does my straight talk samsung galaxy s3 get so hot?
Lots of phones get hot, it all depends on what apps you have running and talk time. When you run wifi and bluetooth it uses up power an many phones run hot. In my opinion to hot. My Fire Phone runs hot and the battery lasts shorter than my older phone without all this extra apps. If you turn off bluetooth it will be less hot and if you dont need wifi all the time turn it off until you do need it. No way around this one.
Jan 30, 2015 | Samsung Cell Phones
Can't turn on blu 5 phone with power button
hi, did you ever figure out a solution
Mar 07, 2014 | Blu Cell Phones
Using battery quickly Thomson MID 1002
Have you tried turning off background apps.
Bring up your recent apps usage with the touchscreen button that looks like 2 windows,when you see the list of apps put your finger on one and swipe left or right ,this should close the app .
Try using Task Manager also to close anything unwanted.
Look for an app called" Wake Lock Detector" ,It can tell you what is running in the background using up battery power.
Hope this helps, even if it is a bit late.
Davo...
Jan 21, 2014 | Tablets & eReaders
Lt25 battery drain
backup your data and try to factory reset your phone. try the phone without reinstalling accounts and apps. if ok, try to reinstall accounts and apps.
Dec 14, 2013 | Sony LT25I XPERIA V 4G LTE QUADBAND...
I purchased a Maxwest Orbit 5400 a week ago. Even with the phone turned off, the phone charged very slowly. I mentioned it to the vendor, and he recommended that I change batteries. I did so, but the...
Could be your charger (cord). Borrow another of the same type and try it. Make sure you aren't plugged into a power strip or surge protector.
May 05, 2017 | Cell Phones
Xperia Play Battery Drain and screen malfunction during charge.
Apps and services in the background drain your phone even while in standby mode. Turning off your 3G or 4G connection will deprive you of the internet but it will still permit you to get phone calls. Meanwhile, you are not having apps such as Google constantly draining your power in the background. And they are, even in standby mode. Charge your phone frequently to help preserve battery life.
Sep 17, 2017 | Sony Ericsson - Xperia PLAY Mobile Phone -...
My phone went dead and now only the red led light will come on the phone will not
Try to replace battery,might only be the problem,otherwise need to update the firmware due to software crash.
Here's a procedure on how to fix your phone.
FOLLOW ME
Thank you for visiting FixYa...
Jul 21, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
Battery power just seems to drain away very quickly
Please check the voltage on the terminals of the battery in the phone. If the voltage is good then check the voltage on the battery, if low the battery is faulty as it may not be retaining the required current factor. Best way to confirm is to swap with one of your friend's phone.
If adapter voltage output is low , try and check with another adapter before it can be changed.
Mar 03, 2011 | Cell Phones
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
