Question about Garden
Mcculloch strimmer/brush cutter - cuts out when throttle opened
Hi I have a McCulloch strimmer which starts ok but when I open the throttle it just dies. Also I have to keep the choke slightly on to get it to idle. I have replaced the petrol/oil mixture and I am sure that is ok. The shaft seems to spin freely enough. Maybe a mixture problem or the like. Would appreciate some help.
Ritchie
  • Anonymous Mar 31, 2014
    33cc straight shaft brush cutter what settings on side lever do I have it on to start plus do I need to have throttle handle pressed on?
    Difficulty starting?
  • 155 Answers
Hi sounds like it could need a diaphram kit in the carby if it has mixture screws one markedl for low speed and one marked h for high speed you can try winding out the low speed screw a bit but if that does not work it will definatly need a kit.
Posted on Jul 25, 2009
There is a small mesh filter behind the plate by the throttle stop remove the plate clean the filter and all will be well
Posted on Aug 05, 2009
How to load new cutting line onto a McCulloch Strimmer TM250
You can probably find a Youtube demonstration video.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jul 16, 2014 | McCulloch 41201-33 Line Head, Models...
Mcculloch petrol strimmer
Agnes take of the cutting head again and see if it runs at full speed without it. If it does you have either put the head on too tight or it's the wrong head.
May 11, 2014 | Garden
Mcculloch mt270 strimmer cuts out when I press the trigger
Carburetor needs replacement. Possibly primer bulb assembly as well.
Contact us
User manuals
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Sep 26, 2012 | McCulloch Garden
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 | Garden
Oil for Mc Culloch M T 325 Cls, weed trimmer
Hi and welcome to FixYa, I am Kelly. I looked up your manual here:
http://www.mccullochpower.com/node7877.aspx and entered MT325CLS as the model number No such number. There is a different model number / product code that may start with 957 on the data plate / label.
I also checked Australia and UK without any success.
http://www.mcculloch.biz/uk/support/owners-manuals/?query=Trimmer&types=O
http://www.mcculloch.biz/au/support/owners-manuals/?query=Brush+cutter&types=O
I tried trimmers and brush cutters for both regions and the US McCulloch site. If you have a better model number (Product code) I will look again.
Kelly
Sep 24, 2011 | Garden
I have a McCulloch Cabrio 433l Petrol Strimmer & Edge Cutter which starts ok but the throttle doesnt work i cant get the case open to investigate the problem to ascetain what is causing the problem the...
If its the same as mine, you need to take off the air filter cover (two allen keys) and then you will probably see that the throttle cable has come out of its fixing on the carb. Hook back in and away you go!
May 15, 2010 | McCulloch Garden
Mcculloch Virginia hedge cutter manual
mcculloch virginia mh542 hedge trimmer, fires 1st time, will only tick over roughly on full choke only then stalls when throttle applied, I have fitted new plug'cleaned air filter and new fuel mix but no change.
Nov 25, 2009 | Garden
Muculloch brush cutter wont start. No spark from plug.
If you have correctly diagnosed the problem as no spark, you will need to replace the ignition module. Unfortunately McCulloch dealers and McCulloch parts are very hard to find these days. If yoou do not have a dealer in yoour are who has the part you need, contact southern supply company at 205-833-2525 or email them at southern.supply@mindspring.com and I feel sure Jason or someone there can help you.
Sep 21, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Mcculloch super 6-10 chain saw
the throttle stop had worked loose and would drift from low to high while running. Reset and tightened.
Jan 16, 2009 | McCulloch Garden
Garden Logo
1,775 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
