Question about Refrigerators
Frigeraire mod.FRS6LF7JBO WAS FREEZING UP LOWERED DIALS. THEN. REFRIGERATOR SIDE WARM.!?
IB4G2008
  • 3587 Answers
SOURCE: top shelf on refrigerator side freezes everything into ice
well..that's most likely due to a problem with the relationship between the control and the compressor.
is your unit under warranty?
Posted on Jun 03, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Side by side refrigerator- will not freeze or get cold
The main question is does the compressor at the back work or not. If it is running (constantly), then I'm afraid you need a replacement which is a service engineer job. If it never runs, then it is almost certainly the control system at fault. This will probably be a circuit board replacement to fix.
Posted on Dec 31, 2008
SOURCE: ge profile refrigerator
I just read on another site that the fluctuation is a normal part of the defrost cycle. (Down to -15 first then up to 15+). I have this hapen in my side by side. Also notice that the -15 in the freezer seems to be cold enough to sometime freeze the lettuce. Also on when the freezer is at 15+ now my ice cream melts. This is sad, if this is normal?
Posted on Mar 22, 2009
  • 46 Answers
SOURCE: 2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
Posted on Aug 01, 2009
  • 4793 Answers
SOURCE: top of refrigerator is warm and bottom freezes
poss answer is drain hole/vent blocked,as unit auto defrosts water/vapour collects at bottom and when unit swiches back on it freezes,poke out drain with thin wire with a small piece of cloth dipped in clorine bleach or blow out with air hose.do not use hot water to manually defrost/ clean drain holes every 6 months
Posted on Feb 09, 2010
Refrigerator is freezing fresh food in refrigerator ...side by side Kenmore I think its the thermostat
turn the dial in the refrigerator side down to a lower number if on 4 now try 3 or 2
Nov 25, 2016 | Kenmore Refrigerators
How do I stop food freezing in the main part of my Kelvinator Twin air no frost 500 series refrigerator
there is a dial inside the refrigerator side to turn the temp up or down . rotate the dial to a lower number for warmer
Aug 31, 2016 | Kelvinator Refrigerators
Temperature control
i had food freezing in fridge. dial turned up and cured the problem
Mar 01, 2013 | Maytag Refrigerators
Amana fridge (mod #sxd22s2) is freezing foods on bottom level- dial turned to lowest setting & temp. is 28 to 32 degs.at bottom of fridge.
seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
Nov 27, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Hi: I have a 9yr old profile refrig, mod #tfx25prb...
What is your refrigerator cold setting? Try lowering the temp to to the medium setting.
Items in the lower part of the fridge will freeze if the setting is too high. (P.S. Cold air "sinks" so the lower part of the fridge will be colder. Cutting the "number" setting on the fridge does stop air flow though.
Oct 03, 2017 | Refrigerators
Fresh food side too warm
Refrigerator nguyen@ite.net 40 F or lower is the recommended refrigerator temperature to slow bacterial growth and maintain quality. Freezing occurs at 32 F; adjust refrigerator accordingly between 32 F and 40 F to prevent unwanted freezing, such as freezing milk.
http://lancaster.unl.edu/food/ciq-fridge-freezer-thermometer.shtml
Jun 09, 2009 | GE GSS25JFM Side by Side Refrigerator
Beko LF320 temperature dial numbered 1 to 10 which way is coldest?
Right to the point people. ok to make it warmer, it is the lower the number
thanks and go night ;)
Oct 01, 2008 | Refrigerators
Which way do you turn the temp. knob
loper the number on the thermostat dial, warmer the fridge. higher the number, colder the fridge. normal setting is about "3"
Apr 19, 2007 | Magic Chef MCBR170 Compact Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
