Question about Tivo Televison & Video
Tv screen went black while watching and reset tivo no help,I have sound but no menu nor change channels
  • 3 Answers
SOURCE: TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Posted on Aug 20, 2006
SOURCE: BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Posted on Jan 16, 2008
SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Posted on Oct 13, 2008
SOURCE: Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Posted on Oct 17, 2008
ginko
  • 19396 Answers
SOURCE: Sanyo DP42746 - Screen went black and no sound. Power light on.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Jun 16, 2009
TV was working fine untl I accidentally hit the Menu button, then the screen went black except for the top bar that shows the channel, program name, description, etc...
Press the TIVO button. This should return you to the main screen. If this doesn't work, the box is most likely hung up. Unpolug the power cord, count to 10 and plug it back in. It will take a few minutes to boot back up, but this should fix the problem.
Jul 17, 2013 | Tivo Series 2 80-Hours Video Recorder
Tv signal blacks out periodically
You might want to consider if this is a Cable box/TIVO issue before blaming the receiver. After all, if you can pause and rewind live TV you're probably watching all content through the hard drive.
Or suspect a marginal connection from the TIVO to the receiver if that is what you have. Does the receiver give any indication of digital signal loss when you lose audio?
I skip some of this exposure by running the video staright to the TV (the more interconnects, the more opportunities for problems).
Jul 01, 2010 | Audio Players & Recorders
Sanyo Flat screen
try to check the settings of your tv if all ok. if ok its a problem in your TV circuit board try to resolder maybe some sections is cold solder. if not its a service mode. trust me!
May 20, 2009 | Sanyo DP26648-R 26 in. LCD TV
Blue screen on WD-52525
Hi, Standby i'll sent you how.for a while
Apr 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
Black screen but have sound
If it is not a hardware problem, it is most likely the Closed Captioning system.
If you can still see the on-screen menu, go into your TV's menus and disable Closed Captioning.
May 14, 2008 | Toshiba 36AX60 36" TV
Tivo tv screen frozen
It could be your tuner, can you/have you tried changing to another channel?
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
TV or Satellite Box Problem?
Do you have a VCR or DVD recorder? If yes, set it to record what you are watching. After a "blackout" rewind the tape and review it. If there is a blackout on the tape, the problem is the sallite box, if not, it is the TV! QED
May 23, 2007 | Sound Ideas Twentieth Century Fox -...
Menu, volume and channel emblems will not show up
take your set to a tech the tv system control circuit might have damage, that circuit controls OSD,channel memory. it is an ic that controls that circuit along with other components.good luck.
Mar 26, 2007 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
Top Tivo Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
