Question about Home
I am looking for the instructions for a can you imagine clock
I change the time on the clock but when I turn the motor off and restart, the time goes back to the original time. How do I get it to keep the time after I change it?
does cigarette lighter work you most likely have a blown fuse in the memory of clock it is part of the stereo but has 2 fuses that function it, power and memory. If its in the radio/clock all presets on radio usually go out to, look for blown fuse.
Apr 01, 2013 | 2010 GMC Terrain SLT-2
I set the clock for a morining time, but it goes off in the evening.
There should be some kind of indication whether you are setting time in AM or PM. You may have missed this as you rotated through the time setting
Dec 17, 2012 | MZB Imagination SpongeBob SquarePants...
How do you set the clock
According to the manual, you press the clock button (This is not very helpful!) I imagine you press CLOCK then use the number to enter the time (so for 11:30, press 1, press 1, press 3, press 0) then (probably) press CLOCK again
Jul 11, 2011 | Kenmore 64002 Microwave Oven
I need instructions on how to opeerate an SUSPENDED ANIMATION ALARM MESSAGE CLOCK
There are 4 control buttons hidden behind a triangular sliding door on the front. Slide the door down, press the middle button, adjust time and date, etc. with other buttons.
Nov 05, 2010 | Can You Imagine Time Machine Tabletop...
Skyscan 34202 Projection
I doubt there is a way to change that, but it's also not clear which way it's supposed to go anyway.  Mine projects "right side up" if you are facing the same direction as the clock is facing - that is imagine you are looking away from the face of the clock.  It is upside down if you are looking at the clock's readout.  One way to solve the problem would be for you to turn the wheel of the projector to make it face the opposite wall.  It will then be right side up.
Oct 11, 2008 | SkyScan 34202 Clock Radio
Instruction manual
What make and model number is your clock?
Sep 02, 2008 | Zenith Z166S Clock Radio
Can't reset my clock
With the car either running or in Aux, press and hold the clock button until the clock display flashes. Then, press '4' to enter program mode, '7' for hours and '8' for minutes...
Sep 13, 2007 | Alpine CDE-7828
Home Logo
32 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
