Question about Fossil Watches
I want to replace all the bracelet of my fossil 6,418,706 b1woman. With the time the appereance turns yellowish. Fossil do not have representation in Mexico. Could you tell me what can I do please?
    New Friend:
  • 5 Answers
I don't know if it can be done?
Posted on May 07, 2017
  • Anonymous May 08, 2017
    Thank you Bob!
SOURCE: fossil watch me1001 bracelet adjustment
I took mine to a watch store, and had them remove a link.
Posted on Dec 26, 2007
  • 3 Answers
SOURCE: Fossil Brazelet
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
1 push pin like you use on bulletin boards with a plastic head
1 small hammer like a tack hammer
1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Dec 31, 2007
SOURCE: Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to wont keep time. I only have 2 buttons on the to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Posted on Nov 09, 2008
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
Posted on Apr 04, 2009
SOURCE: Time change Fossil JR 9120
i already found one link with all Fossil manuals.
Thank´s for your support.
Posted on Feb 09, 2010
The crystal on my fossil. Watch is got a scratch on it can I send it to you for repair or how do I. Do this
Sure David, send it to us. The cost is $85.00 plus shipping and handling of $8.50.
Or your local jeweller could probably do it for half the price as crystals are standard sizes.
Warranty & Repairs - Fossil
  1. Cached
  2. Similar
Battery, case, crystal, strap, or bracelet; Damage resulting from improper handling, ... click here); Repairs if the watch was not originally purchased from an authorized Fossil retailer ... If this is the case, you will be able to select a replacement.
Non Warranty Repairs
Apr 08, 2017 | The Watches
Altering the ******** a watch braclet 6,418,706 B1
use a fine pointed tip tool such as the prong of a fork and between links on bracelet there is a pin between each.. use prong to press out the pin
Feb 22, 2012 | Fossil Blue watch #AM3574 Watch for Men
Which is a better gift for my boyfriend? Please do help. :)
the swiss watch. also a new fishing rod and a case of beer
Apr 06, 2017 | Timex Indiglo Watches
Adjust expansion bracelet
Since all bracelets are simiar, the instructions I found on the Fossil web site may help you.
I have found some instructions on the Fossil website and since most
watches are very similar you can try the method described there.
Go to "", go to the bottom of the page and you will see a
menu, click on "customer care", and then look under "Product Info" on
the left and you will see "watch instructions"
Go down the list to the bottom and under "Phillipe Stark" there is an item "bracelet instructions".
Feb 14, 2010 | Watches
I cant work my watch
Rate me, please
Jul 31, 2009 | Fossil Watch Style # CH2545
Remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Jan 09, 2009 | Fossil Arkitekt watch
Need pin for band on Fossil Am 3754
Measure distance between the lugs of your watch. Find the nearest watchmaker and ask for spring lug of that size (this is if you need to attach band to watch).
If you need a pin for bracelet links- measure width of bracelet and ask for split pin of that size.
Dec 18, 2008 | Fossil Watches
Fossil watch me1001 bracelet adjustment
Dec 08, 2007 | Watches
Watches Logo
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
