Question about Singer Sewing Machines
I cannot get my Singer Quick Sew to make any stitches on cloth, I found someone else had asked the same question, but, I found no resolution....
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 1116 Answers
SOURCE: hand held singer sew quick
Remove the plastic pin holding the bobbin (thread source) - careful to not lose the spring.
You may need a pair of pliers to get it loose the first time.
Press down on the edge of the bobbin so the pliers can grip the pin - lay a piece of material over the pin so the plies do not gouge the plastic - twist and pull.
Posted on Jun 01, 2009
SOURCE: singer handheld quick stitch instruction manual
find it here: http://www.sewwhat.net/millie/Manuals/CEX300k.pdf
Posted on Jul 04, 2010
SOURCE: singer 404 sewing machine
I would first make sure the thread tension is adjusted properly. if this does not fix your issue, check the point on the shuttle hook and make sure it is not broken off. it should come to a needle sharp point. if the tip is broken off it may not pick up the thread from the needle properly. then double check the timing and the needle shaft depth. first, make sure your needle is fully seated and tightened down. the groove in the needle should face forward. there are two timing marks on the needle shaft. at maximum depth you should see both lines and the top line should be right at the bottom of the needle shaft bushing. then as the shaft goes back up, when the bottom line is at the bottom of the bushing the point of the shuttle hook should be right behind the needle and centered in the indentation on the back of the needle. you may need to make minor adjustments on the needle shaft depth depending on what brand and type of needles you are using.
Posted on Jul 07, 2010
hazelgrace
  • 340 Answers
SOURCE: I have bought a singer
Hi
You can download a free manual from the Singer site.
http://www.singerco.com/accessories/manuals.html
Just type in 4210 and click on search.
On the next page click on free download!
This manual is in French, English and Spanish.
Hope this helps.
Posted on Nov 15, 2010
What way are we supposed to put in the replacement needle in a singer stitch sew quick machine? The loop stitch isn't looping
The needle should be inserted so that the flat side faces the front of the Sew Quick. (The flat side should face the set screw that secures the needle in the Sew Quick.) See figure 11 (on page 2) of the manual. One link to the manual is currently: http://www.hayneedle.com/images/PDF/MICL002.pdf . Make sure that you are using the DHx1 needle.
If the stitches still aren't looping, make sure that you have threaded the needle and bobbin correctly. The thread should start at the back of the needle and be pulled to the front.
I hope this helps.
Aug 17, 2016 | Singer Sewing Machines
What is the difference in the length of the needle on a "handy stitch" as opposed to the "stitch sew quick machine?
Check your manual for the "System" of needle
a normal sewing machine needle has a "System" or dimension
called 15x1 or 705 H. That indicates the length, the circumference
etc. If the needle you received with the machine is the same length as the above system then you should be ok. Also most often the needle package for most machines will be labeled "Universal"
Aug 04, 2014 | Singer Handy Stitch Hand Held Portable...
I have a brand new singer stitch sew quick machine, apparently the machine works, when i use a cloth to try stitching it does not make any stitches
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Apr 03, 2014 | Singer Stitch Sew Quick Sewing Machine
I brought a new "Singer
Why not just return it and get another one? Most reviews are bad on this product, and say do not buy it, too much trouble.
Oct 31, 2010 | Singer Stitch Sew Quick Sewing Machine
Singer simple sewing machine will not sew
Mar 15, 2009 | Singer 3116 Simple
Sewing Machines Logo
18 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
