The labels are off the capacitor's and need to know their rating condenser model S1BA-018K
  • Heating & Co... Master
  • 1,869 Answers
I can't find anything on the 1.5 ton. If you look at the data plates on both motor and compressor it should tell you mfd ratings. Good Luck!!
Posted on May 07, 2017
Need part number for dual run capacitor for Armstrong Concept 10 air conditioner
The armstrong concept 10 comes in 7 different sizes. We need the model number off the outdoor unit.
Aug 08, 2017 | Heating & Cooling
Replaced condenser fan motor with OEM and I replaced the dual run capacitor with exact same rating and the condenser fan motor still will not run, I wired the way it came off (3wires brown to f on...
One way to test the motor and the board is to bypass the board. You need to direct wire the motor and test to see if it comes on. Then you know the motor is good and the board is bad. Not sure exactly what board your talking about though. Condensers don't have defrost timers on them. Can u post your model no. and any pictures of the unit would help also.
Aug 04, 2013 | Heating & Cooling
I NEED TO KNOW WHAT SIZE CAPACITOR GOES IN MODEL NUMBER- CK49-1B
The old capacitor has it's rating on the side. If the old capacitor is missing the you will have to read the capacitor rating on the data plate for the compressor and the one for the condenser fan motor as well. Each of them will tell you what capacitor they require.The compressor will be something like 35µF.
Data plate for the compressor in located on the top of the compressor or on the side and will look similar to the one of the ones pictured below. The fan motor one will be on the side of the motor, you will have to remove the top of the condensing unit to see the fan label.
Jun 19, 2011 | Goodman Heating & Cooling
My ac unit out side has power but does not turn on ... Why?
Hi!!
There are a few things that can cause the compressor/condenser fan no to start.
1 - Faulty thermostat control unit. Take wall thermostat switch cover off and check for continuity on terminals R and G and R and Y while termostat is in the AUTO/COOL setting.
2 - System Low/High pressure. Check refrigerant pressure, if too lowor too High, Low Presssure or High Pressure Switch will not let compressor kick in.
3 - Start up selenoid and/or transformer defective.
4 - Defective capacitor. Check capacitance, it should be +-5% of the capacitors rating. Rating is stated on capacitor's label.
Keep me posted
Jul 23, 2010 | Heating & Cooling
The condensor is not working but it is getting power
HI!!
The condenser motor should kik in togheter with the compressor, check the fan motor's capacitor capacitance, it must give you a reading equal to what is specified in the capacitor's label +-5%, if it reads more or less than that, replace. NOTE: you must discharge the capacitor before handling.
If capacitor is OK!! check motor if it gets hot an doesn't turn, replace. Average life of condenser motors is about 4 to 5 years, it varies depending use and weather.
Don't forget to rate this answer!! Good Luck!!
Jul 17, 2010 | Weather King 10AJA6001AH Air Conditioner
What type of capacitor comes with a 5 ton Goodman Air conditioning unit model number CK60-1C
The best way to know what size capacitor it needs is to look on the label of the fan motor itself. It will tell you the size it needs. Condenser fan motors get replaced all the time with different capacitors needed. If you cant find a label or its too weathered, try to find a model number on the fan motor and any local A/C supply store will be able to look it up. Hope this helps.
Jun 21, 2010 | Goodman CKL60AR60 Air Conditioner
Goodman model F48F97A76 need to know what the
if your condenser fan motor is not bad. change out fan capacitor
Apr 08, 2010 | Heating & Cooling
No tag to find out the size of the condenser unit to know the rating for a dual capacitor
information is on the capacitor . mfd all so on the motor allso on the compressor has a model and serial # get that info call the local part supply house they might tell you what ya need are ya sure it is a bad capacitor. Tom
Jun 27, 2009 | Ruud UAKA042 Air Conditioner
Charging the system
look at the data sticker on the unit it will tell factory charge by oz
Feb 19, 2009 | Frigidaire Heating & Cooling
Ruud heat pump capacitor size
A hard start or turbo 2000 will not work if the run capacitor is bad. You will need to contact a ruud supply house or dealer with model and serial to find out the exact match. I have checked my sources and came up empty handed. You could try getting a 35/5 MFD at 440V or a 45/5 MFD at 440V as these are the most common capacitors used in Rheem and Ruud equipment. The key is that you will need to check your amp draws on both motors against the nameplate rating to make sure that you are not over-amping the motor. Also check the nameplates on both of the motors. Most condenser fan motors and some compressors list the capacitor size they require in a somewhat less than conspicious location on the label.
Jun 26, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
