Question about Garden
1960 oliver 770 industral tractor - Garden
What is the ignition point gap in an oliver 1550 tractor?
Most point gaps fall into a range of .010" to .014". You should be able to get it running in that range. You can then readjust to different gaps for best performance.
Mar 04, 2015 | Garden
Rear end locked up FOUND a cotter pin in the drain oil Ford 8 n stanard transmission tractor 1950-1960
dismantle it.
inspect all parts. for damage or excessive were.
same with all machines.
inspect and measure parts as the FSM states
FSM is the factory service manual. good luck for 1950
join a tractor form ,we do not have one here.
Jun 18, 2014 | Cars & Trucks
Removing oil plug on MTD 760-770 lawn tractors
Here's a link to the manual. With a picture of the drain plug its hard to say.
Jun 07, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Case tractor problems
If it sort of fades out, slows down and dies, I'd bet on a float valve issue. If it quits cold, look for an ignition issue. Could be a bad coil. Heats up and fails.
May 13, 2014 | Garden
MY 1070 starts but when you shift it stops
There is an interlock that prevents starting the tractor when in gear and another interlock which prevents the tractor from running when you get off of the seat and the tractor is in gear. Check these interlocks.
Sep 27, 2012 | John Deere 670 770 870 970 1070 Compact...
I need a parts diagram for a cav fuel injection pump. Came off david Brown tractor Model 770 A.
Go to case IH parts on line and find your tractor model and pump diagram
Aug 06, 2011 | Diesel Garden
Ford 770 loader front cylinder leaks fluid when operated forward or back. repair process for changing seal
61506-fd.jpg Ford Lift Cover Repair Kit (770)
Ford Lift Cover Repair Kit. Fits 500 thur 4000 . Repalces: 3B5564
depending on year of your tractor it takes a rebuild kit, assuming your cylinder and ram are in good shape and free of rust, nicks and scratches, if the ram is damaged a new seal kit will be shortlived, its pretty straing forward repair, the only thing you may need is an adjustable spanner wrench set to remove the endcaps hope this steers you in the right direction
Nov 22, 2009 | Ford Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
