Question about Briggs Garden
Briggs and straton presssure washer model# RO20569 won't run with water pressure or supply on, will run with no water.
  • 313 Answers
SOURCE: pressure washer wont idle and run
check the pressure replace valve or a bypass valve
Posted on Jun 08, 2008
Editor925
  • 285 Answers
SOURCE: Pressure washer with no pressure
Are you priming the water lines before you switch on the power?
i.e. with power OFF, hook up hose and turn hose on (doesn't need to have much hose pressure), then take your spray gun or attachment and pull the trigger and allow water to flow through the system (at hose pressure obviously). You might need to gravity feed it if its not flowing through...
But you will generally only get pressure once all the air is removed from the lines and the pump is pushing water only... Once you have water flow and lines are primed, switch on pump and see if that solves it.
Posted on Mar 17, 2009
  • 15 Answers
SOURCE: I have a Briggs & Stratton gas power washer. This
Sounds like the unloader is not working correctly. Try replacing it and see what happens.
Posted on Apr 23, 2009
lester482529
  • 226 Answers
SOURCE: MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Posted on Jul 16, 2009
SOURCE: I have a Briggs & Stratton pressure washer,
If #1 doesn't work, the ports in your carb could be clogged. I just dealt with this problem this weekend. This is a relatively easy fix. Locate your carburetor and find the aluminum bowl underneath. On the bottom of the bowl, you'll find a bolt. Loosen the bolt (gasoline will come out because the bowl is a reservoir for gas, but please make sure you've turned the gas supply off) and remove the bolt and the bowl. Clean any debris out of the bowl. The ports are holes in the bolt you removed. Make sure that air can pass through these holes (I blow through them, but I don't mind the taste of gas too much. Probably NOT healthy. You can use thin wire, carb cleaner, etc..) Reassemble and your motor may start, if this was the problem. Make sure that the bowl seats properly and that you are careful screwing in the bolt, lest you cross-thread it. Hope that helps.
Posted on Apr 29, 2010
Engine working fine, but water not coming out
Couple of things, is the water supply good? if that's a yes, then check to see if there is a way to engage / disengage the pump, some models offer that, if engaged and good water supply, then it has to be your pump
May 31, 2014 | Briggs & Stratton Briggs Stratton 2550...
Brigs n straton pressure washer won t stay running unless you put or keep starting fluid in in
Loosen the carb bowl nut until it begins leaking into the shallow clear glass bowl you placed beneath it. It may take a minute to have drained the water out of the bowl and another minute or so to get some more from the gas tank. With the glass bowl you will be able to see the water in the bottom and gas floating on top of it. When you see the gas on top then tighten the bowl nut and try to crank. (Choking helps draw out water still in carb) Return gas collected. to tank but do not let the water go back in.
Sep 12, 2013 | Psi Blue Max 2200 High Pressure Gas Power...
My briggs and straton troy bilt 675 pressure washer has no pressure
This means overhaul the valves on the pump. You can get a kit for this that has all the seals and valves. The pressure regulator might also be stuck open
Oct 13, 2012 | Briggs & Stratton Garden
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
We have a 6.25 /Briggs & Straton we have cleaned
You should have two fuel lines going from the carb to the tank, one has a filter,
make sure both lines are good without any breaks or cracks. if the filter is dirty
you may need to replace it. you can fish it out of the gas tank by making a hook
on a wired coat hanger, try to remove the filter and put the line back in the tank
make sure they are both submerged, if it runs just replace the filter, good luck!
Jun 26, 2011 | Briggs and Stratton 020275 Elite Series...
When using the sweep nozzle (yellow tip), the pressure starts and stops but the machine works fine when using the circluar nozzle(red)
usually when the power washer pressure stops the machine is running out of water. the sweep function uses a little more water than the round wash tip. Make sure there are no leaks in the supply hose and that the supply faucet is turned on all the way and has plenty of "flow". also make sure the water connection at the washer is not leaking. use a new rubber washer to make a good seal on the supply hose on both ends. if either end leaks or can **** air, just a little bit of air into the pressure washer will cause it to loose pressure.
Apr 20, 2011 | Briggs & Stratton Briggs Stratton 1800...
Crafstman 22hp briggs and straton engine, I've changed spark plugs, air filter...when engine runs it does so unevenly and at times backfires. What can I do to solve the problem?
Don't use the choke, turn the lean all the way to the right and back off 1 and a half turn, its running too rich, usually find this screw under bowl on carb, don't mess with the other screws, take air breather off and let breath without choking, if you have to use the choke after this start with just a little.
Jul 02, 2010 | Briggs Stratton 020273 Elite Series...
I have a 3000 PSI Honda pressure washer. The motor
May have sediment buildup in the pump housing, ???
Jun 04, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
