Question about Nokia 6300 Cellular Phone
I have a nokia 6300 phone that wont hold charge ive put a new battery in it but this still hasnt worked.any solutions??
  • 71 Answers
1st, enter *#7328748263373738# this "might" allow you in to reset the security code.if it not working
Call your provider, get the PUK code, once entered, it will allow you back in the the phone,reseting the security back to the default code of 12345.
Posted on Jul 25, 2009
My 6300 wont switch on. {battery is charged} iv used a replacement none nokia battery,it was working ok. it wont charge either
Hii
Firstly never try to use local battery because they are not good enough and damages handset .
check your battery in other mobile if its works in other mobile then your handset need to be FLASHING ie. updation is required.
Update your handset and never use local battery always use nokia brand.
Thanks to help you
Aug 20, 2011 | Nokia 6300 Cellular Phone
My keygard code wont work or ive accidentely chaged it but how do i fix it
Full format solution for NOKIA
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Mar 10, 2010 | Nokia 6300 Cell Phone
My nokia 53100 express music phone wont turn on
First you need to measure battery voltage with a multimetre to diagnose and repair. Post battery voltage and we can star from there!
Sep 01, 2009 | Nokia 6300 Cellular Phone
Nokia 6300 Switching off
Purchasing a new phone is easy and everyone is always in a hurry to use new phone but never go through the manual properly. You did the same you didn't put the battery on charge for 24 hours. Now to check your phone take another charged battery for nokia put it inside your phone and start it. It will deffinetly work. In order to revive your dead battery keep your battery on charge while the phone is switched off for minimum 24 hours. If it gets revived its ok or else purchase a new one.
Jul 25, 2009 | Nokia 6300 Cellular Phone
NOKIA 6300 WONT CHARGE
Sir, the problem lies in the connector (it is where you plug the charger). It is not functioning anymore. Try replacing that. But before anything else, i suggest that you have the phone reformatted first. Sometimes, this can solve any problem. To do that, turn the power off. then press and hold this in this sequence: green/talk + 3 + *, then press the power on. release the buttons when you see the reformat starting.
Jul 19, 2009 | Nokia 6300 Cell Phone
Nokia 6300 Wont Start
OK CHANGE UR BATTERIE IT WILL ON OK RATE ME
Feb 01, 2009 | Nokia 6300 Cellular Phone
Nokia 6300 wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Apr 29, 2017 | Nokia 6300 Cellular Phone
My nokia 6300 can't turn on.. i dropped it awhile ago, when i checked, it was still okay,,, but when i ran out of battery and tried to charge it, it wont turn on anymore,,, but the blue light around it...
5.Wait 10 seconds.
S
Apr 06, 2017 | Nokia 6300 Cellular Phone
Nothing happens
try via another battery or charger....or else connector is out of order or may b handset hardware issue.
Aug 20, 2007 | Nokia 6300 Cellular Phone
Wont charge!
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models.
Aug 19, 2007 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
91 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
