Question about Cell Phones
Where do i get a sd card and where does install
    Master:
  • 507 Answers
Normally for microSD cards its in the back of the phone under the battery or near the SIM tray of the phone but always likely to be around the battery area
Posted on May 06, 2017
  • Cell Phones Master
  • 2,271 Answers
Amazon.com and into the sd card slot
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
How do I move my downloaded apps to my SD card?
You really should check the manual, to see how to move or to install the apps on the SD card. Not all Android tablets and phones work the same. You not giving any detail of yours does not make this easier.
Some systems can install the apps on the SD card and they can run from the card. Others only allow you to put apps on the SD card, but before you can use them, you have to install them in the internal memory.
Again, check the manual.
Apr 19, 2015 | Tablets & eReaders
How do i install to the sd card?
Sometimes you can't directly install to sdcard. You may need to move it there by going to settings, applications and click any app and click move to sd card. Not all apps are able to be moved to sd card or some phones/Tablets do not allow moving apps on sd card
Mar 06, 2015 | Samsung Sch R720 Admire - Black metro Pcs...
Dgs 160 Note if sd card is installed is on the
What size memory cards are you trying to use? The I-60 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Sep 15, 2013 | Cameras
Why i cn't install apps on my sd card for galaxy
Try installing App 2 SD from Android Market. You should be able to move the installed apps to SD card using this application. Galaxy Mini comes with Froyo and hence you should be able to use this app and move possible apps to SD Card. Moving the app to SD card also depends on whether the developer has enabled the feature to move his app to SD card. App 2 SD will only be able to move the apps which have this feature enabled by developer to SD card.
Hope this helps.
Jul 16, 2011 | Android Apps
I have a JVC 20 GB camcorder. Model GZ-MG2-1U. Before I tried to install an 8MB SD I selected on the menu to protect all. I turned the camera off, installed the SD card, turned the power on and then I...
There should not be anything to install when inserting an SD card, all you do is put the card in the card slot. If you tell it to format you have to go into the menu first and tell the camera which you are referring to the card or the harddrive. If you didnt change the setting to SD card when you did give it the format command than that is why your data was lost. If you are having an SD card error make sure that the little slide switch on the card is set as not to protect the card that will give the error sometimes. I hope this helps
Sep 15, 2010 | JVC Video Cameras
Installation
To answer install question,I don't see a format option,so you pull the card out and put it in to install.
This phone uses a micro sd card,and most times they come with an adapter, the adapter is just a regular sd card, you need a usb sd card
reader,they are real cheap, Ill poat a great site to get one below.
I do not have this phone,but it depends on the operating system on your computer, if the card is in the phone and you have the plug
for the computer, and plug in the phone,your PC might see the sd card in the phone and it will list the phone as a drive, that is,your hard drive shows as C, so your phone could show as E,f, depends
on what you have for drives. Windows will either pop up a windows
that says, installed phone,or install driver, could not install phone.
This is a page of readers you can get to plug your sd card into your
PC.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=sd+card++card+readers&x=0&y=0
The rosewill is what your looking for, this kind of reader, it supports
sd,mmc, you can get anyone, as long as it supports sd card.
Apr 02, 2009 | Samsung Eternity Cell Phone
SD CARD is not working
I reccomend that if you can find a driver for your sd card slot, install it so that your slot could be compatible with all sd cards including HCSD cards.
Jan 26, 2009 | Acer Aspire 3690-2196 Notebook
-SD Card was renamed
From what I remember when this happens you empty the SD slot and do a soft reset. When the SD card is put back in it will be SD card. Similar steps when you put your SD slot device in.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
