Question about Refrigerators
Gouges in ceramic stovetop. Roasting pan set on a very hot burner. Pan had remnants of plastic packaging on the bottom. Plastic packaging hit the burner and explosive bits of ceramic blew up.
  • Refrigerators Master
  • 3,203 Answers
Lots of plastics have a very low melting point and such plastic coming into contact with a very hot surface would probably vaporise fairly explosively and that is likely to be the cause.
Posted on May 06, 2017
Testimonial: "Vernon, Thanks. But can I fix the ceramic?"
  • Will Travis
    Will Travis May 06, 2017
  • Vernon Taylor May 07, 2017
    Sorry it is beyond my experience but I suspect it is unlikely as most repair compounds are bound with resins that are unlikely to withstand the very high temperatures.
    I suggest you enquire with the hob manufacturer and then perhaps a number of repairers and the suppliers of specialised industrial repair solutions.
2 Suggested Answers
t0pc4t
  • 132 Answers
SOURCE: Refrigerator drip pans too expensive are there alternatives?
Whats the sponge for ??
Caution with the type of plastic tray you use.
Theory is - yes you can do what you suggest - However - dependant on the location of the drip tray (above motor ! ! ! ) some plastics will 'perish' and become brittle / fibrous.
Posted on Aug 14, 2008
How do i change the oil pan on a 2007 ford f150 4.2L v6?
4.2L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
    WARNING
    During engine repair procedures, cleanliness is extremely important. Any foreign material, including any material created while cleaning gasket surfaces, that enters the oil passages, coolant passages or the oil pan can cause engine failure.
  2. Raise and safely support the vehicle.
  3. Remove the starter.
  4. Drain the engine oil. Install the drain plug when finished.
  5. Remove the 4 bolts and the crossmember.
  6. Remove the 3 oil pan-to-transmission bolts.
  7. Remove the 17 bolts and the oil pan.
  8. Remove and discard the oil pan rear seal.
To install:
WARNING
Do not use metal scrapers, wire brushes, power abrasive discs or other abrasive means to clean the sealing surfaces. These tools cause scratches and gouges which make leak paths. Use silicone gasket remover and a plastic scraping tool to remove all traces of old sealant. Follow the directions on the packaging.
  1. Clean the gasket mating surfaces using silicone gasket remover, a plastic scraping tool and metal surface prep. Follow the directions on the packaging.
    NOTE
    If the oil pan is not secured within 4 minutes, the sealant must be removed and the sealing areas cleaned. To clean the sealing area, use silicone gasket remover and metal surface prep. Follow the directions on the packaging. Failure to follow this procedure can cause future oil leakage.
  2. Apply silicone gasket and sealant to the oil pan sealing areas shown and install the oil pan rear seal.
  3. Apply silicone gasket and sealant to the rear main bearing cap.
  4. Install the oil pan rear seal.
  5. Apply a bead of silicone gasket and sealant to the oil pan mating surface.
  6. Position the oil pan and install the bolts. Tighten the bolts in the sequence shown. Tighten to 10 Nm (89 inch lbs.).
  7. Install the 3 oil pan-to-transmission bolts. Tighten to 34 Nm (25 ft. lbs).
  8. Install the starter.
  9. Position the crossmember and install the 4 bolts. Tighten to 90 Nm (66 ft. lbs.).
Feb 15, 2016 | Ford Cars & Trucks
How do i change out the oil pan?
4.2L Engine
    WARNING
To install:
WARNING
    NOTE
Feb 15, 2016 | Cars & Trucks
What is the advantage of gas range than gas stove?
There is much confusion about those terms, especially when used by suppliers / online webshops. A great indepth article about the issue can be found here: http://www.ebay.com/gds/What-s-the-Difference-Between-a-Stove-and-Range-/10000000177628290/g.html
Below is - imho - the most related paragraph:
'Many people use the terms oven, stove, and range interchangeably. However, buyers that plan to purchase a stove or a range should understand the purported meanings of each of these common words. First, the term stove technically refers only to the stovetop, which includes a number of burners (typically four to six) and is used for surface cooking such as boiling, frying, pan-searing, and other methods. The oven is an enclosed device that is used for baking, broiling, roasting, and other cooking methods. It employs concentrated heat within the enclosed area, which is usually delivered via heated coils in the top and the bottom of the stove. The term "range," as defined in Webster's Dictionary, actually refers to the combination of stovetop and oven into one kitchen appliance.'
Hope this helps :)
Jun 27, 2014 | Whirlpool Kitchen Ranges
Peeling nonstick coating
It can't be fixed. In the future, use only plastic cooking utensils so they won't scratch off the non stick coating. You can line the pan with foil if it is a baking pan, if it's a frying pan, there's no fixing it.
Apr 07, 2014 | KitchenAid 16-Inch by 13.5-Inch Roaster...
Should I cover my roasting pan or not?
when using a roasting pan, it depends on the type of meat and the recipe if you should cover the pan or not.
meat with a high fat content eg duck doesnt need to be covered.
lean cuts should be covered when roasted for a long time to keep the juices and soften the meat.
May 06, 2013 | Home
What is the difference between roasting pans and broilers?
Roasting pants are for big peicesof meat becuase they are big, deep pans so the meat will cook and be flavoured from its juice.
A broiler has shallow sides so the meat cooks faster. It also has a slotted bottom so the pan drains.
Jan 14, 2013 | Home
I want to serve three kinds of soup in my Rival roaster oven with the three pans. Must I put water in the large pan that the three small pans rest in? Must i put water between the large pan and the...
Your Owner's Guide for the Rival 18 qt. Roaster Oven with Buffet Server can be found here:
http://www.rivalproducts.com/manuals/MANUALS/RO180BR-C_43_18972586.PDF
Refer to page 6 for complete instructions.
You do not add water or anything below the roasting pan. You fill your roasting pan 1/2 to 3/4 full with water, place in the empty serving dishes, then preheat at 350 degrees until hot (about 1/2 hour).
Then fill the serving dishes and reduce heat to 250 degrees. You may need to adjust heat and more hot water if necessary.
Feb 21, 2011 | Rival 18 Qt Roaster Oven with Buffet...
Just bought a house with a Kenmore ceramic top range. model is 790.9601. The red light on the top left of the panel that indicates that a burner is hot keeps blinking even though the range hasn't been...
Sorry to read about your problem, I hope this helps you out.
those are hot plate sensor's just to let you know, that glass maybe hot, they will turn off when the stovetop cools down.
now if you happen to put a hot pan on the cook-top, lets say from the oven. the lites will come on.
in your case I think is is defective and staying on
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Kenmore Kitchen Ranges
TOP FREEZER REFRIGERATOR WITHOUT ICEMAKER LEAKS ONTO TOP SHELF AND UNDER BOTTOM DRAWER
the condensate drain hose is blocked.
remove the plastic rear cover in the freezer; locate the drain opening;
it's about 1/2 inch in diameter; it drains into a pan at the bottom of the refrigerator. using a funnel and, a small pan, pour hot water through the blocked hose until water flows into the drain pan again.
remove the condensate pan pour the water out and, reinstall the pan.
Jul 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Stovetop ceramic burner turned black and smooth
Do you have a proper ceramic top scraper ?, if not buy one (about £10 UK)
Get a bottle of cream cleanser and a plastic type pan scrubber
Soak the area with warm water , pour on some cream cleanser and work it in with the scrubber , when you have formed a nice creamy froth use the scraper to get underneath the scorching
It is a lot of hard work but it does come off
Sep 28, 2009 | GE Kitchen Ranges
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
