Question about Sony Televison & Video
The tv comes on says Sony and then the screen becomes blue and it shows hdni4. All of the cords are secure and the wifi is connected
  • 2334 Answers
SOURCE: blue deflection
I would suggest to click here to find information on the problem you have with your TV.
If the adjustments do not work, it means that the blue tube is defective or the video amplifier IC.
Good Luck.
Posted on Aug 21, 2008
SOURCE: Cloudy Blue Color Covering Whole Screen
I think its time for sony to face a claas action, they do not supply parts in less than 7 years, and the unit should not have been sold so $high, they should buy them back, that is the best solution
Posted on Mar 12, 2009
  • 157 Answers
SOURCE: Sony KP-51WS500
sony has a problem with that model the pix tubes short not going to be worth fixing
Posted on Sep 02, 2009
  • 668 Answers
SOURCE: turn on the big screen sony tv, but fades to blue
You probably have a bad BLUE CRT. Due to the cost and the length of time it would take to repair, I would not invest the money into it. It would require a Qualified Service Person to come to your home and remove the BLUE CRT assembly and send it back to SONY to be rebuilt. Estimated cost would be around 800.00. I would check prices of a replacement set.
I hope this helps,
Skyassoc
Posted on Oct 28, 2009
Testimonial: "Thanks that saves me alot of hassle, I will just get the man a new TV."
  • 1481 Answers
SOURCE: pc connected to tv, but only a blue screen shows
you need to go to control panel/display/setting tab/Advanced/Monitor or Display tab and chose the correct output device in there....
Posted on Dec 10, 2009
I have a toshiba hdmi flat screen tv and I also have wifi. and a Sony Blue ray / dvd player and I want to know how to get net flix. Can you assist? Thanks
Netflix is a streaming service that runs as an application on an internet capable smart tv or similar device. Choices for stand-alone hardware include "AppleTV" "Google Chrome" they will connect to your tv and your wifi to stream content. You will still need to register for an account. If you have Sony PlayStation or Xbox they also have Netflix apps. If you have a smart tv you should either already have it in your tv app list or be able to download it from the connected App Store.
Jan 07, 2018 | Sony Televison & Video
How do I connect wi on sony bravia?
Assuming you have a working wifi system in your house and it probably has a security password/key that need to be entered into any device before it will fully connect. Wifi will be visible but not usable , which sounds like you symptoms.
Try finding out you wifi security settings and using them in the TV set up.
Aug 09, 2015 | Sony KDL-40W600BE 40" BRAVIA Smart...
I have play station 3 how should it show up when checking should it be under a WEP Key I do not understand how all this works I just want to make sure everything is done right so I don't have
The PS3 has 2 different ways it can connect. The first, and most reccomended, is by a ethernet cord to your router directly. The second, is by wifi. When you connect wifi, you go to network settings, it will suggest wired but you can continue with wifi connection, then select "wireless". It will ask you to auto scan, or manually put in the SSID. Select "Auto" then when your router info shows up, it will ask for the security info (WEP) this is where you enter the security code that you use for all of your devices that use the wireless connection. If the key is correct, it will ask you to test your connection. Everything is automatic from there.
Oct 15, 2014 | Sony Playstation 3 (PS3) Console
Vertical lines blue
Check area around TV for interference--cordless phone--wifi---also check input cords and hdmi cable or coax cable--- make sure connections are tight and secure
Aug 18, 2012 | Mitsubishi LT-52149 52 in. LCD HDTV
There is no wifi showing up on my playstation 3
You have to turn the WIFI option on for the PS3 to recognize wifi connections.
  • Go to "Network Settings" under the "Settings" option in the Main Menu.
  • Select the "Internet Connection Settings" tab and select "Yes" when the system displays a new screen saying you will be disconnected from the Internet.
  • Choose "Easy" on the next screen.
  • Choose "Wireless" when it asks for what type of connection you would like to use.
  • Select "Scan" on the next screen.
  • Select your wifi internet connection.
  • Select your Security Settings and enter your password
  • .Test the connection by selecting "Test Connection".
  • If everything works out, your network information should show up.
Cheers!
Feb 25, 2011 | Sony Playstation 3 (PS3) Console
Nov 14, 2008 | Sony KP-65WV600 65" Rear Projection...
Playback
when I plug in the RPU DC cord from my camera to the input on my tv I get nothing. Is my input jack bad or what. Also, if I tried the s video jack from the camera to the tv, would that work??? I don't know what the AV out jack is for I don't have a cord for that
Nov 12, 2008 | Sony Handycam CCD-TRV308 Camcorder
Blue deflection
Good Luck.
Aug 21, 2008 | Sony KP-57WS500 57" Rear Projection...
Ps3
Are you trying to connect via Wifi or via a LAN (a cord).
If Wifi, are you sure there is a network? Do you have the network key? A network key is basically a 10+ character gibberish password that you get when you set up a secure wireless network... It is easier to connect to a non-secure network, but no one recommends keeping a non-secure network... because its not secure ;)
If LAN, try plugging the cord into a computer, and seeing if the computer can connect to the LAN. If a computer can connect, I see no reason the PS3 wouldn't be able to. If the computer can't connect, verify the other end of the cord is plugged into your router/wall, and that it is securely seated. If a router, unplug the power for 10 seconds, then plug it back in and try again.
May 06, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
