Question about Ameriglide Rave Stair Lift
How do you adjust belt tension on ameriglide chair lift
2 Suggested Answers
  • 175 Answers
SOURCE: My Pride (Ameriglide) Backpacker Plus Lift Stops
If it's stopping in the same spot, it is a limit switch that isn't making contact with the lift sensor.
Here's a link to the wiring diagram that shows where the limit switches are.
ftp://webfiles.pridemobility.com/pdf_files/ipbs/domestic_us/silverstar/us_backpacker_plus_ipb.pdf
If it is tripping the circuit breaker, either your are trying to lift too heavy a weight, or the motor is pulling too much amperage due to previous abuse, or misuse. These are good lifts, and if you bought it new, then get ahold of your dealer and Pride will fix the problem. If you bought it used, they may have been using it to haul concrete...who knows?
Posted on Jul 09, 2009
Code f7 showing & chair won't lift
Going to the user's manual: https://www.ameriglide.com/cache/1475784382000/resources/product/615/productDocument/292.pdf
I see that the F code indicates that there is a fault at the motor, possibly corrected by doing a "reset". Directions are in the user manual. The 7 indicates a fault at the "downside safety edge", the little micro-switch on the downhill side of the footplate. See if there is something holding that little projecting piece of plastic that triggers the micro-switch from springing back out to its normal position. Good luck!
Mar 03, 2015 | Acorn Stairlifts Acorn Superglide 120...
How do I release the rear seat belt that is stuck to the back of the chair
you will have to be patiant with this as long as the seat belt tensioners havent gone try to pull the belt so some tension comes of it so it can roll back into the spool or jiggle it by bulling on it quickley should be a simple fix hope this helps
Aug 18, 2012 | 2007 Hyundai Santa Fe Limited
Where is the tensioner pulley located on a 1994 pontiac bonneville? and how do I adjust it to get the alternator back on? Thanx
the tensioner is located directly below where the alternator bolts on. it is an automatic adjusting tensioner so you can't adjust it . you can only move the pulley back and forth to allow slack in the drive belt.
Jul 26, 2011 | 1994 Pontiac Bonneville
How to remove alternator on a 2005 range rover
Hi
Click here
the link above should tell you all you need to know if you get stuck or have any problems give me a shout back ok
Oct 26, 2010 | Land Rover Range Rover Cars & Trucks
Everything seems to work fine except a small slip in the track about every 30 seconds or so. Is there something that needs to be tightened?
The walking belt may be too loose. If you have made recent adjustments, lubricated, or had repairs, a belt can slip if not tightened. The belt can slip if you have too much friction or if the belt has been recently lubricated. If lube does not help your problem and you have exhausted all other possibilities, the walking belt is most likely worn out and must be replaced.
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Feb 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
How to do you adjust the belt on a Pro form crosswalk 380? The belt is getting loose and I lost the manual.
Feb 20, 2010 | Proform 730 Folding Treadmill Model...
How do you change the drive belt to alternator on a 1991 subaru xt
just loosen alternator bracket adjusting bolt push down alternator slip drive belt over alternator drive pulley.when done installing new belt lift up on alternator to increase tension on belt.if alternator drive belt tension correct from longest span of belt take thumb press on drive belt should get 1/2 inch deflection once correct tighten alternator bracket adjusting bolt.
Dec 23, 2009 | 1991 Subaru XT6
Jun 13, 2009 | Ameriglide Double Entry Platform Lift for...
Change a belt?
Replacing the belt is not that hard.
  1. You have to take the back of the dryer off.
  2. Then lift the tension arm on the motor releasing the pressure on the belt.
  3. Inspect the tension pulley, checking the bearings on the pulley.
  4. Wrap the new belt around the drum, and wrap it around the tension pulley, lifting the tension pulley to adjust the belt.
  5. Reinstall the back of the dryer.
Please rate this solution
Aug 03, 2008 | Whirlpool LEQ9858P Electric Dryer
Replacing belt
This is easiest done if you lift up the front of the washer, and support it. Some washers will have a tension pulley to release the tension on the belt. Replace the belt, Adjust the tension on the belt so that when it is tight you can twist the belt 1/4 turn.
Aug 02, 2008 | Amana Washing Machines
Ameriglide Rave Stair Lift Logo
Top Ameriglide Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Ameriglide Exercise and Fitnes Expert? Answer questions, earn points and help others
