Question about Brother Office Equipment & Supplies
My brother dcp130c printer has the fault print unable 50 can you help
    President:
  • 1,197 Answers
I am sorry to hear you are having problems with your printer. The paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Be sure printer is off when you do this.
That should fix it.
You error code seems to indicate that your encorder strip is twisted or has some debris on spot on it which will make the unit will malfunction. You may need to take it to a service center if you do not have any experience in dissasembling your unit as this will bee needed to reeat your strip.
If you wish to do it your self...
1) Lift cover. Remove the two plastic panels covering wires. Mark down position of cables then remove them, and remove the now-freed top scanner section entirely.
2) Remove screws from top plastic shell. There's two in the back and four in the front. There's also two plastic tabs in the front that must be bent aside before you can remove the top shell. Dont break tabs!
3) Gently put the encoder strip back in its plastic guide.
reassemble and power it up. You should be good now.
if ur problem persists even after replacing the encoder strip back... contact canon.... as it might indicate a hardware failure and it needs to be serviced....
Posted on Jul 25, 2009
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Aug 14, 2017 | The Office Equipment & Supplies
My brother printer has an error unable to clean 50
XXXXX XXXXX look on the printer, do you have these keys:
Menu/Set, Black Start, or Function?
Brother Printer Support
Sep 28, 2012 | Brother LC51BK Print cartridge, Inkjet...
Brother dcp-165c print unable 50
how ca n i fix my brother dcp 195 c unable 50?
Nov 21, 2010 | Brother DCP 165C Compact Color Inkjet...
Says unable to print 4f, see troubleshooting and routine maintenance. please help.
This is a print head failure of some type. Turn off the printer, disconnect the power cord and lift up the scanner unit. Check for any paper or foreign object. See if you can slide the printhead and check under it. If the printhead will not move easily, do not force it. If the printhead is all the way to the right, you will not be able to move it. Use a flashlight to check for any foreign objects or paper scraps soaked with ink. Remove any foreign stuff that you find.
Sep 15, 2010 | Brother MFC-5460CN All-In-One InkJet...
Message unable to print 50
I have the same problem. Most people i asked about it said it is a mechanical problem. It's better to bring it to a brother service center near you.
Feb 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
21 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
