Question about Garden
I got a fatmax power station for Christmas. The compressor stopped working ,makes noise but won't blow up a tire. It did when I first got it...Can the compressor be replaced? Is there any warranty?
Model number pprh7ds. Ser number 3100397
  • 53 Answers
SOURCE: Dead replaced fuse now makes loud noise
Yes that noise is causing your fuse to blow. Machine gun sound sounds like the High Voltage Capacitor or High voltage diode is bad. (Loud humming sound is usually a bad magnetron or bad power transformer). Most of these parts are inexpensive, except for the magnetron. But most of the repair bill is most likely going to be for labor.
Based on your model, it looks like an over the range microwave. And to fix any of these problems require the removal of the microwave from the wall. So its up to you if you want to deal with that hassle. But you also have to consider that you'll probably have a hard time trying to find a new microwave that will fit.
Posted on Mar 28, 2008
SOURCE: Maytag stopped getting cold, buzzing noise every now and then after pwr outage
Frig requires either compressor relay or the compressor itself...should have some warranty still, so call an authorized servicer. Ray
Posted on May 30, 2008
  • 6982 Answers
SOURCE: AC was blowing and just stopped
Check blower motor fuse. If blown replace. Be aware. If fuse again blows or you find fuse to be in good condition it indicates a problem in blower circut/components. Do NOT replace with larger fuse to cover problem it will cause further damage. $$$
good luck
Posted on Mar 12, 2009
  • 462 Answers
SOURCE: Model KM-450MAB--Ice Machine Making Beaping Noise
Keeps on beeping? Every 3 to 4 seconds? Try putting the thermostat wires together. An open bin thermostat will cause this problem and the board see it and starts beeping.
Posted on Mar 28, 2009
  • 286 Answers
SOURCE: Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Posted on May 15, 2009
I got a new Stanley fat max power station for Christmas, today went to air up a tire (first time ever used) compressor runs great but air will not come out of nozzle. What can I do besides cry?
read the user manual to see what has to be done to pump air
you may have to put it on the tire stem to depress the valve in the hose and the stem
Jul 17, 2017 | Stanley Air Tools & Compressors
How can I get a parts repair manual/list for a stanley fatmax 3.8 cfm compressor
try searching for stanley fatmax compressor . I think bostitch owns it
Nov 03, 2014 | Measuring Tools & Sensors
Stanley fatmax 450
Open up the case and look inside. A wire may have come off.
i had a brand new compressor that wouldn't power on. A wire was not connected. After reconnecting and a positive testing I put it back together. It ran for five minutes and stopped. It turns out the wire was too short (factory install) and came disconnected each time the compressor was turned on due to the vibration. I rerouted the wire so it wasn't so tight. Problem solved.
Oct 29, 2013 | Stanley STA-J45C09 450 Watt Jump Starter...
I have a HYUNDAI TUSCON 2006, My compressor is working for 3-5 seconds only then it stops for 45 seconds again it works for short and stops again, morever air flow is weak and not cold.
Constant clicking of the compressor is an indication the system is low on refrigerant. Most vehicles require a minimum of 2lbs of refrigerant to power the compressor. The constant shutting off is a safety measure to protect the compressor from burning out. Most service stations do AC service now. They will typically run a leak detection test to find where the refrigerant is escaping. They won't usually "top off" refrigerant due to legal restrictions. If you're somewhat handy, most auto parts stores will sell you a refill kit that includes refrigerant, oil, and a hose.
May 14, 2011 | 2006 Hyundai Tucson
After 60 mph steering and dashboard vibrates and it won`t stop in my 1998 vrg galant
Your front tires are out of balance or are out of round. The best thing to do is bring your tires in to a service station for a rebalance. This way the person who is doing the work will be able to either balance the tire properly and while the tire is spinning, check for seperated belts. Hope this helps.
Mar 29, 2011 | Mitsubishi Galant Cars & Trucks
I have a porter cable 6 gal pancake 135 psi compressor. How can I change the cut off and cut on pressure. I've been trying to add air to my car tires and it will not fill the tire all the way up. I was...
where the plug in goes into the pressure switch you can take the cap off and you will see the electrical points and on the inside of the plastic cap it will you show you the two screws to adjust there. one screw will be to raise or lower the min and max pressure equally and the other is to adjust the differential between them. But make sure not to exceed recommended pressure of the compressor or you will blow safety valves, the safety valve will say what pressure it will go off at
Jan 18, 2011 | Garden
My fridge is blowing out cool air but not cold air
There is several things can cause that To tested first unplug your fringe Remove the panel behind your fridge Reconnect the fridge Touch your compressor us the big black round thing on the back Does it field vibrating and making noise? If yes that means you have a bad compressor or refrigerant leak If it makes clacking noise or a laud buzz noise then stop Deftly you have a bad compressor If make no noise or vibration ones of ever First remove the thermostat and make a bridge in between the thermostat cables live the green one alone is just ground If your compressor start working then buy a new thermostat if don?t change any thing Remove the black box on the side of the compressor and you shut see thee plugs or one plug whit thee holes use a voltmeter and check for power, You shut get around 120vots between tow terminals if you have power Go to the local appliance part store a buy a ?hard star kit? if your compressor doesn?t start you have a bad compressor. If you don?t have power you need to change either your defrost timer or control board Depending of the fridge model
Jun 08, 2009 | Kenmore 60721 Refrigerator
Screeching noise, then a/c stops blowing cold air. Still blows air, just not cold air.
it could be the air conditioning clutch going out. to check turn your car on and idle it with ac on and hood open. at the ac compressor it will have a pulley on it with a clutch that engages when the air conditioning is on. if it engages and disengages it can be the clutch itself has gone bad, the ac clutch will also disengage if there is not enough freon in the ac system, will also engage and disengage if the pressure gets too high in the ac system. Depending on the year of the vehicle it will disengage at full throttle and come back on when you are not at full throttle.
If it is a metallic sounding screech for example take a coke can and drag it across pavement kind of sound it could be a bad compressor or a bad ac clutch. If it is a more rubbery sound for example a car spinning its tires kind of noise it could be a loose belt.
1. Check to make sure all belts are tight under hood
2. start car and look at ac compressor to make sure compressor pulley is turning and that the fan clutch is engaged spinning
Aug 09, 2008 | Mercedes-Benz 400-Class Cars & Trucks
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
