Question about Samsung Tablets & eReaders
Never Had this problem but once .and forget how to get it back no sound on samsung tablet help
How i can reset my samsung tablet when i forget my password
You can unlock a device remotely if you have it registered to a Samsung account. On another device, go to and log into your account. (I was able to reset my Samsung account password using the link before proceeding.) On the next screen, click Find, then More, then Unlock My Device. I had to reset all passwords, PIN, etc for the tablet, but so far it looks like all my downloads and other personal data is intact. Hope this helps!
Jun 02, 2017 | Samsung Tablets & eReaders
I have forgotten mypin number on my Android Samsung galaxy tablet and now it's locked and i dont want to use the factory reset option.Please help me.
There is no other way, a factory reset is the only way. It is pretty impossible to 'forget' a code you are using 20 times a day :>)
Apr 20, 2017 | Samsung Tablets & eReaders
A WiFi connection potensWL has popped up on my wifi settings. I do not know what this is but want to delete it. How do i do it? I have a Samsung Galaxy tab 2.
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them. To do this, tap on the connection in >Settings >Wireless and networks and ou will be given 3 options, Connect, Forget, Cancel. You need "Forget".
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code.
It is worth remembering that your tablet will always notify you (via Wireless and Network settings) of all wireless networks that are within ita range.
Feb 28, 2015 | Samsung Galaxy Tab on 3 Mobile Tablet PC
I bought a Samsung GALAXY Tab 4 7.0 tablet several weeks ago and it has worked beautifully until this week. It will no lomger access the internet or even attempt to scan for internet access. How can I
Have you tried turning it off, letting it sit for a minute or so, and then turning it back on? You need to turn your tablet/phone off and reboot periodically or it "forgets" how to do things - just like a computer, because that is what it is. Another thing you can check for (under Settings) is, have you accidentally turned off the Wi-Fi button? Or have you accidentally put the tablet in Airplane Mode (also under Settings)? Either of those two things will make your tablet unable to search and connect to available wi-fi networks. Hope that helps.
Oct 20, 2014 | Samsung 8GB Galaxy Tab 4 Multi-Touch 7.0"...
Why does my Galaxy Tab 3 does not take a charge?
sounds like the battery is faulty, speak to the supplier you got it from it needs a replacment battery check your warranty
Nov 13, 2017 | Tablets & eReaders
I had a samsung galaxy tab GT-P7300 , the problem is its a password protected and i have forgot the passwoed, so kinly help meout
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
Mar 07, 2014 | Samsung Galaxy Tab Tablet PC
Locked out of RCA RCT6077W2 Tablet running Android
so far i have not found any usb drivers for this device so looks like you will have to flip it over on the back side their is a reset button use a pin or paper clip to hold it down should reset it and do the trick, in the meantime i am also looking for usb drivers for the device so that I can gain root access to it.
Oct 27, 2013 | Tablets & eReaders
Forgot my password to samsung galaxy tab 2
Apr 01, 2013 | Samsung Galaxy Tab Tablet PC
It stopped working, went black and has a sound like a loud fan working. Can't switch it off or do anything with it. Just making this running please. Fay
HI baring 16 listen You can get do a hard reset on the Samsung tablet. I must warn you that if you do a hard reset on the tablet you will lose all of your data. Next if your hearing a fan sound in the tablet. The tablet it self may be struggling to do simple operations on it. Where did you buy the tablet from. The steps to doing a hard reset on the tablet are as follow. 1 You need to hold both the power button and menu home key buttons at the same time. You will see the reboot screen come up. DO a wipe user information on it. It will begin wiping the tablet. You will have to reset set up the tablet after it is finish.If you still hear the fan sound take it back to the place of purchase for an exchange. Hope this helps
Mar 21, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
26 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
