Question about Air Tools & Compressors
Have a Jura. Capresso F-9 Tray Missing illuminated and machine will not function.
Tried to depress the white trigger with no luck. Any ideas?
SOURCE: Jura Capresso Problem
check out this link:
Posted on Dec 30, 2007
SOURCE: jura capresso
If you gind too fine, it will overload the pump and result in the "open tap" a few seconds into brew. Rinse and gind coarser to clear out malfunction.
Posted on Jan 20, 2008
  • 4 Answers
SOURCE: Tray empty message
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Posted on Oct 13, 2009
  • 80 Answers
SOURCE: I have a Jura Capresso Impressa S9 and it keeps
try this:clean with brus two metal contact on drip tray
Posted on Mar 05, 2010
SOURCE: Jura Capresso Impressa S9- no steam
I had a similar problem. I took off the side and rear cover, followed the hose that comes from the steam wand to the rear of hte unit. It enters a solenoid made by ACL Italy. I dismantled the solenoid unit by disconnecting the two hose ends, removing the relay, and unscrewing the plunger unit (vertical pipe). The plunger unit internals should move freely up and down like a piston in a cylinder , powered by a small spring. In my unit, this plunger was calcified and seized. I soaked it in boiling water and pressed on it gently several times and it unstuck. I put it all back together again and presto! Good luck
Posted on Mar 30, 2010
Tray missing error
The "sensor" is most likely a micro-switch. When the tray is in it actuates the switch and closes a circuit indicating to the controller that the tray is in place. Sorry to tell you this but it will have to be disassembled to replace the switch if it has failed as the micro-switches are usually sealed items that are not normally cleaned.
Nov 11, 2013 | Jura Capresso C1500 Espresso & Coffee...
Drawer will not go back in for Jura Capresso impressa
For Jura F7 Series, "Tray Missing, can't put it back in". With a small flashlight, look in to the cavity which the tray and grounds container reside in. Along the right side above a slot to the end, you'll see a white micro switch. with a "Tooth Pick" simply press the switch inward (to the right) and hold till the machine cycles the Levcer / Flap up and out of the way.! Put your tray and grounds container back in and begin brewing!! -dh
Mar 17, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
I have the F-9. Came home after using the machine this morning and noticed the hot water button light was lit while the machine was off. I tried to start the machine and it isn't doing anything. ...
Hi, Sounds like a sencor on the boiler is faulty. It needs to go into the repair shop. you cant buy parts for Jura. You have to use an autherised repairer. Not many Jura repairers around. Im a repairer based on the sunshine coast Qld. Dazza
Sep 23, 2011 | Jura Capresso Impressa F9 Espresso Machine
Tray missing
On the right side inside you can see a small slot. Try using a screwdiver or something to click this small microswitch, if the message disappears, then you need to check your tray and see if something is broken. You can also try to move a little on the tray when it`s in the machine. However if clicking on the microswitch doesn`t help, you need to have this switch replaced in a servicecenter
May 27, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura capresso z5 not working
Call Nick or Anthony at Style Cafe on 0844 2279229 they have a wealth of knowledge on these machines and can Service them if required
Jun 11, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso F7
You can find some detail procedure in this tip below
Try it since it have help some other with same problem.
Dec 30, 2007 | Jura Capresso F8 Espresso Machine
Air Tools & Compressors Logo
103 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
