Question about Maytag Washing Machines
Hi, I have a Maytag Centennial washer. We recently experienced a power surge in our home. The washer does everything it should - except cycle. Could this be the time motor? Thank you! David
    Master:
  • 507 Answers
Depending on your washer model it is most likely in some events of a power surge that the timer knob could be damaged and need of replacement
Posted on May 06, 2017
  • 1 more comment
  • Anonymous May 15, 2017
    Thank you so much, Denkichu! I am ordering the part now. I'll let you know how things work.
    Before I order - this is the timer itself, correct? The part that the knob attaches to, not the physical knob that you turn?
  • Denkichu
    Denkichu May 15, 2017
    your welcome and yes that would be the part there now notice that even so if its not a timer that doesnt move its a switching knob but your welcome glad i could help ;P
How do you clean out the drain pump maytag centennial washer
Maytag & Whirlpool & Kenmore Washer Pump Repair ...
? 3:44
https://www.youtube.com/watch?v=97rBObh_3mQ
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Repair your own Maytag Top Load Washer which has the following ... Took me awhile to unclog as an entire ...
Washer Won't Drain - Pump Clogged with Sock - Repair ...
? 1:53
https://www.youtube.com/watch?v=tHT7PmmFc9w
Dec 2, 2011 - Uploaded by Tomahawk DIY
Washing machine pump clogged with a sock. ... I searched hi and low trying to figure out why my washing ...
HE Maytag Centennial Washer Fix - YouTube
? 31:43
https://www.youtube.com/watch?v=CoTlOr3Gxuk
Nov 15, 2013 - Uploaded by mike3000ace1
So how do you open the washer to pull out the Manual? .... +mike3000ace1 Hi, I have a 2011 Maytag ...
Maytag Centennial Washer Drain, Transmission ...
Jan 05, 2016 | Maytag Washing Machines
Coninuosly repeats spin cycle, any suggestions how to remedy this? I have to manually cancel the cycle in order for the machine to stop recycling through spin
I had a Centennial washer on a service call doing this just the other day... After putting it trough diagnostics I found no errors and all the washer's mechanics tested okay. After resetting the control by putting it trough the diagnostics mode it continued to repeat cycles without restarting the washer.
  • Try running it through diagnostics and see what error codes are in the memory. (Guide is linked below)
  • What are the codes? do they give any more clues?
  • clear the codes and run a test cycle.
  • does it work?
  • if it checks out properly with the diagnostics it's probably a bad control board...
Maytag Centennial Washer Diagnostic Guide
If it does turn out to be the control try contacting Maytag (Whirlpool) for a parts concession... Whirlpool customer service guide is linked below.
Hope that helps! Good luck!
Jun 16, 2015 | Maytag Centennial Top Load Washer
Wash cycle will agitate 3 spins then nothing for a few minutes then 3 more and nothing again and repeat over and over
you may want to put it through a diagnostics cycle and check for error codes... Maytag Centennial Washer Repair Guide
The tub sensor can cause the washer to act strangely like that. Also there are two mechanical styles of washer branded Maytag Centennial. The model number would help to know we are talking about the one I think we are talking about.
Hope that helps!
May 27, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag centennial top load washer control know tics but does not advance through teh cycles
The cycle dial runs like a clock and advances through each cycle and opens and closes each stage by contacts so I would say that the 1st cycle contact has burnt out which would prevent or in some cases a short will burn out the lot, usually from a power surge so if you don't have the knowledge i'm afraid it is the serviceman. But be assured that you make sure he makes that one of the first points of checking.
Jul 11, 2014 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag centennial washer will not agitate
If it is belt driven the belt might be broken. It is underneath the washer
Apr 03, 2014 | Maytag Centennial Top Load Washer
I have a Maytag Centennial Top Load Washer. When I start a wash load, the machine is starting in a "spin" cycle. It does not matter which cycle I choose. I have let it run through to see if it...
Unfortunately it sounds like your gearbox may be seized. I would strongly recommend getting an experienced maytag service agent in to have a look at it because they are quite difficult to repair. I'm sorry for the bad news, hope it helped though.
Jul 27, 2011 | Maytag Centennial MTW5800TW Top Load...
Maytag centennial washer - power went out while washer was operating. When power was restored the washer does not cycle. I have to turn it manually through the cycles.
Set the timer to any off position. Unplug the unit for 10 minutes. Plug it back in and try that. The worst thing
you can do to a Maytag washer is advance the timer yourself...hope this helps.
Apr 02, 2011 | Maytag Centennial MTW5800TW Top Load...
Washing Machines Logo
57 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
