Question about Exercise & Fitness
Looking for a cable of a ROWEN BR 3010 machine . One of the 3 cables is nearly snapping.
2 Suggested Answers
SOURCE: I need to disassemble Petzl Myo 3 - snapped cable
i also have the same problem can you please give me instructions on how to disassemble it? thanks!
Posted on Oct 18, 2010
How to open bonnet on Suzuki Wagon R (2004) - cable broken!
If the cable is broken at the release handle cut the outer cable sheath back and grip the inner cable with a pair of locking "Visegrip" pliers and pull. It often helps if someone pushes down on the hood over the latch location to release tension on the latch. If the cable is broken at the latch you will need a car lift to get at it to release it.
Feb 26, 2017 | Suzuki Cars & Trucks
1999 chrysler 300M won't shift out of park. Pulled so ******* the shifter it broke.
possible internal locking pawl stuck fault or adjustment required
ADJUSTMENTS
sourced from another forum
The park interlock cable is part of the brake/shift lever interlock system. Correct cable adjustment is important to proper interlock operation. The gear shift and park lock cables must both be correctly adjusted in order to shift out of PARK.
ADJUSTMENT PROCEDURE
1. Remove floor console as necessary for access to the park lock cable.
2. Shift the transmission into the PARK position.
3. Turn ignition switch to LOCK position. Be sure ignition key cylinder is in the LOCK position. Cable will not adjust correctly in any other position.
NOTE: If the key will not turn to the LOCK position, pull up on the cable lock button and manually move the cable in and out until the key can be turned to the LOCK position.
4. Pull cable lock button up to release cable, if necessary.
5. Remove and discard the cable adjuster lock pin, if a new cable is being installed.
6. Ensure that the cable is free to self-adjust by pushing cable rearward and releasing.
7. Push lock button down until it snaps in place. The lock should be 1-2mm below the surface of the cylindrical portion of the cable
d5fad53b-454e-40de-8326-5998ee796fd6.jpg2010-09-06_193640_8-yevmkukx3b2zymzwvvrzuy4i-4-2.gif
Jan 16, 2017 | 1999 Chrysler 300M
How can I reset totally?
Your question seems to be lacking in specifics but I think I know what you're looking for .
To completely re-set all systems on your car
1. Make sure vehicle is off
2. Disconnect the battery cables
3. Remove the battery and store it somewhere dry
4. leave the battery disconnected overnight
- This allows the capacitors to completely discharge
5. Re-connect the battery the next morning
Hope this is what you need!
Dan
Oct 08, 2015 | Cars & Trucks
Can someone send me a video on how to open the hood of a 1990 Isuzu amigo from the outside
Ive had an isuzu before it always took two people to open, one pulling hood release one pulling up on the hood if ya get it up this way tie u somthing on it so u can reach it an do it all from outside
Aug 04, 2015 | Isuzu Cars & Trucks
How to open the hood if a 1990 Isuzu amigo from the outside when the hood release cable is broken
Hood release repair advice, page 5 - 2CarPros
www.2carpros.com/topics/body/hood-release?page=5Asked by vasti about 3 years ago - 4 Answers; 1994 Isuzu Amigo Engine Problem ...On my 2000 blazer the hood release cable broke and I can't open my hood.
My XJR 400 battles to start when cold
Hi, Rowen and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Faulty fuel pump.
9. Intake air leak.
10. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
11. Enricher valve inoperative.
12. Engine lubricant to heavy (winter operation).
13. Ignition is not functioning properly (possible sensor failure).
14. Faulty ignition coil.
15. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
https://netrider.net.au/threads/efi-cold-start-issues.112524
1993 YAMAHA XJR400
Regular service manual XJR400 4HM1 4HM 000101 maintenance
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Jun 16, 2013 | 1998 Yamaha XJR 400
Brandt wte 1271k diagram
Update :
The problem is on sensor's cable contacts (pins).
It seems that when the machine is working, the vibration "disconnects" the cable from the sensor.
I tried to clean contacts (pins) many times, but the problem reappeared after 2 or 3 weeks. So, I cut a little piece of sensor's plastic case to expose its contacts (pins) and solder directly the cable to sensor's contacts. This method solved the problem months ago.
May 07, 2013 | Washing Machines
Bonnet release cable has snapped how do i get into the engine bay to fit a new one?
it depends where the cable snapped. it it snapped near the opener just get a vice grip plier grip the cable and pull. the cable passes inside the left fender, just remove the fender liner and you can access it from there. if it snapped near the catch you need to remove the bumper and or grille
Jun 02, 2009 | 1994 BMW 3 Series
Exercise & Fitness Logo
27 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
