Question about Refrigerators
After changing filter in PUR water faucet system, light indicator does not go back to green. Why?
SOURCE: Water filter indicator light
On my samsung I needed to press the ice timer and ice mode together for 3 seconds.
Posted on Mar 29, 2008
SOURCE: Water filter light on refrigerator
Found this site and the fix worked for mine. You need to press a combination of buttons and this tells you which ones
Posted on Aug 08, 2008
  • 34 Answers
SOURCE: indicator light for Brita filter not working
I see this alot when I do the Brita tech support
1-800-24-BRITA (US)
Posted on Feb 04, 2009
SOURCE: getting light to turn off after changing water filter
Press and hold the lock and light buttons (lock and water on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks
Posted on Feb 16, 2009
SOURCE: Can't remove the filter from my Pur Flavor Options faucet mount water filter
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Posted on Feb 25, 2009
How do you fix the light in a Pur faucet filter
It could be mineralized, try soaking it in vinegar or scale remover.
Mar 03, 2017 | Refrigerators
How does the pur water filter work? Is it powered by a battery or is something else involved? My light will not light green or red after changing the filter sometime ago. Does it come apart?
it runs by water preasure. filter does not come a part. try to unplug the fridge for few minutes and plug back in. if that does not help see instruction to reset yje unit
Jan 20, 2015 | Refrigerators
Why is my Pur faucet filter so slow? It was not before
You either need to clean the the screen filters prior to as they may be blocked. The filter cartridge itself my need to be changed as you don't say how old it is.
Aug 29, 2013 | PUR 3-Stage Vertical Faucet Mount Gray...
PUR Faucet Mount Water Filter indicator light does not work
Take it loose from the faucet and flip the lever down on the filter in the on position. Take the cap off and remove the filter. Blow hard through it. You should hear a whirling noise of a gear, like a windmill. If not, I use a water dental pic to pulsate into it and clean it out. This is what makes the light work and when flow goes down, the light changes color. It's all mechanical. No battery. Just free up the gear so it turns freely to work the light. If standing in front of a mirror, you can actually see the light come on. PUR doesn't tell you this because they want you to purchase another one.
Dec 17, 2011 | Buck Plumbing
Which glue to reattach chromed plastic to plastic?
Use old fashioned model cement. Not the child safe type. The old type will melt the styrene to the styrene. The new stuff only fills the gap but never really makes a good bond.
Mar 10, 2009 | PUR (FM-9500) Air Purifier
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
Aug 04, 2008 | PUR (FM-9500) Air Purifier
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Nov 18, 2007 | PUR (FM-9500) Air Purifier
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
